Thread Closed
Ideal gasses and the law
Share Thread Thread Tools
Feb6-08, 10:47 AM   #1
I have a ballon on the ground, where it is 20 degrees celcius, and it has a volume of 5L (it is filled with helium). The pressure at the ground is 1 atmosphere. The ballon itself (without helium) weighs 0.1 kg.
I find the force that makes the ballon go up to be:
F_up = (m_air)*g = 58.96 N
F_down = (m_Helium + m_ballon) * g = 9.13 N
So the ballon will go up.
I can also find the number of Helium-moles from n = m/M, and I find that n = 207 moles.
3. The attempt at a solution
My questions are:
As the ballon goes up, the pressure goes down and so does the temperature. I want to know, which parametres are affected by this?
The density of the helium? Yes, because density is written as "rho" = M*p/(R*T), so this changes.
The volume of the helium? yes, this changes as well.
The number of helium-moles? No, this is constant too.
The mass of the helium? Yes, this gets smaller when the temperature goes down since "rho" = m/V.
The pressure inside the balloon? No, this stays the same.
Can you guys please confirm this?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb6-08, 12:24 PM   #2
- the pressure of the balloon is constant also, right?
Thread Closed
Thread Tools
Similar Threads for: Ideal gasses and the law
Thread Forum Replies
pv = nrt / ideal gasses Biology, Chemistry & Other Homework 11
Separating gasses Materials & Chemical Engineering 4
Ideal Gasses, Double-Layered floating objects, and immersion in oil Introductory Physics Homework 0
Exciting gasses Atomic, Solid State, Comp. Physics 5
Need help badly on Gasses Chemistry 2
