Electrocuted by household static…?
  • Thread starter Thread starter rpellerin87
    Static
The discussion centers around the phenomenon of experiencing frequent static electric shocks from household electronics, with a focus on potential causes and solutions. Participants explore various factors contributing to the issue, including environmental conditions and personal habits.
  • Experimental/applied
  • One participant reports experiencing frequent and increasingly painful static shocks when interacting with electronic devices, raising concerns about the safety and implications of these shocks.
  • Another participant suggests that environmental factors, such as wearing rubber shoes and having carpeting during winter, may contribute to the buildup of static electricity.
  • A suggestion is made to check the lamp for faults, as a blown lamp could indicate a coincidence or a more serious electrical issue, and using a voltmeter is recommended to assess the voltage of the lamp housing.
  • Some participants propose using products like Static Guard on carpets and clothing to mitigate static buildup, along with wearing materials that are less prone to accumulating charge.
  • One participant inquires about the potential influence of specific footwear, such as Crocs, and the impact of cold weather on static electricity generation.
  • The use of a humidifier is recommended by multiple participants as a method to reduce static shocks, particularly in low humidity conditions.
  • Another participant emphasizes the importance of ensuring that all electrical outlets are properly grounded to prevent dangerous voltage differentials that could lead to shocks.
Participants express a range of views on the causes of static shocks, with some agreeing on environmental factors and grounding issues, while others focus on personal habits and product solutions. No consensus is reached on a singular cause or solution.
Participants mention various potential causes and solutions without confirming the effectiveness of any specific approach. The discussion reflects a variety of assumptions about environmental conditions and personal practices that may influence static electricity experiences.
Individuals experiencing frequent static shocks in their homes, those interested in the effects of environmental conditions on static electricity, and anyone looking for practical solutions to mitigate static buildup.
rpellerin87
Electrocuted...by household static…?
Hi, lately I find that I have been getting shocked by pretty much anything electronic and it has been getting stronger. Lately it’s seems like I can’t even turn off the light switch without getting a shock, on average I seem to shock myself about 100-150 times a day. It’s usually nothing to complain about but on larger power sources it’s stronger and sometimes painful. For instance when I close my laptop, the shock is so strong that sometimes whichever finger touches the laptop first goes numb for about an hour. Worst part is I think it is still getting worse. Just the other day the light on my desk lamp blew when I accidentally brushed part of it with my finger and was shocked.
So I guess my question is…what the heck is going on here? I really don’t care for having to constantly replace light bulbs and have parts of my hand numb for hours.
Any suggestions on how to stop this? Or at least from getting any worse?
Thanks!
If the lamp (an inanimate object not subject to changes in sensitivity and immune to small static charges) blew, you have either a coincidence or a faulty lamp. Use a voltmeter to check the voltage of the lamp housing with respect to ground.
Yeah, definitely check the lamp; that could be something dangerous.
As for the rest, all that I can think of is to spray a lot of Static Guard or similar product all over your carpets, furniture, and clothing. Also try to wear materials that are less likely to build up a charge, and don't shuffle your feet when you walk.
I bet Russ and Danger have it. OP, have you recently bought a pair of Crocs (or the ripoffs)? Is it cold right now where you live?
Along with your choice of clothing and shoes.
If the weather report in your area is for low humidity then a ruining a humidifier in your home will help a lot.
The temperature may not matter, but if it's hot you tend to perspire which will help alleviate the problem.
First off, get an outlet tester and test all the outlets in your place to make certain that all circuits are properly grounded. If you've got some appliances that are not properly grounded and you get a static-electricity shock when touching them, the voltage differential between the appliance and ground can piggyback on that spark and you become the path to ground.
A humidifier would help reduce normal static shock.
  • · Replies 16 ·
35K
12K
  • · Replies 24 ·
