Solve Matrix w/ C++: Row-Echelon Form
  • Topic: C/C++
  • Thread starter Thread starter greeniguana00
    C++ Matrix
1 reply · 20K views · last reply
greeniguana00
I just thought I'd post this here. It will help you solve a matrix by getting it into row-echelon form (well, close to it anyway). I avoided global variables and tried to make it as expandable as possible.
Code:
#include <iostream>
using namespace std;
void output(int height, int width, long int * matrix)
	cout<<"__________________"<<endl;
	long int (*matrix2)[width];
	matrix2=(long int (*)[width]) matrix;
	int row_temp;
	int column_temp;
	for (row_temp=0;row_temp<height;row_temp++) {
		for (column_temp=0;column_temp<width;column_temp++) {
			cout<<matrix2[row_temp][column_temp]<<" ";
		cout<<endl;
void switch_rows(int row1, int row2, int width, long int * matrix)
	int temp;
	int column_temp;
		temp=matrix2[row1][column_temp];
		matrix2[row1][column_temp]=matrix2[row2][column_temp];
		matrix2[row2][column_temp]=temp;
void multiply_row(int row, long int multiple, int width, long int * matrix)
	int column_temp;
		matrix2[row][column_temp]=matrix2[row][column_temp]*multiple;
void add_rows(int row1, int row2, int width, long int * matrix)
	int temp;
	int column_temp;
		matrix2[row1][column_temp]=matrix2[row1][column_temp]+matrix2[row2][column_temp];
void add_multiple_of_row(int row1, int row2, long int multiple, int width, long int * matrix)
	int temp;
	int column_temp;
		matrix2[row1][column_temp]=matrix2[row1][column_temp]+(matrix2[row2][column_temp]*multiple);
int reduce_column(int column, int block_rows_until, int height, int width, long int * matrix)
	int row_temp;
	int column_temp;
	int temp;
	int selected_row=-1;
	for (row_temp=(height-1);row_temp>=block_rows_until;row_temp--) {
		if (matrix2[row_temp][column]!=0) {
			selected_row=row_temp;
	if (selected_row==-1) {
		return block_rows_until;
	switch_rows(block_rows_until, selected_row, width, matrix);
	for (row_temp=block_rows_until+1;row_temp<height;row_temp++) {
			output(height, width, matrix);
			temp=matrix2[row_temp][column];
			multiply_row(row_temp, matrix2[block_rows_until][column], width, matrix);
			add_multiple_of_row(row_temp, block_rows_until, -(temp), width, matrix);
	block_rows_until++;
int main()
	int width;
	int height;
	cout<<"Height? ";
	cin>>height;
	cout<<"Width? ";
	cin>>width;
	cout<<"Enter in the matrix row by row with entries separated by space:"<<endl;
	long int matrix[height][width];
	int row_temp;
	int column_temp;
			cin>>matrix[row_temp][column_temp];
	long int * matrix_transfer;
	matrix_transfer=(long int *) matrix;
	int current_row=0;
	int current_column=0;
	int solved=0;
	while (solved!=1) {
		current_row=reduce_column(current_column, current_row, height, width, matrix_transfer);
		current_column++;
		if (current_row==(height-1)) {solved=1;}
		if (current_column==(width-1)) {solved=1;}
	output(height, width, matrix_transfer);
	return 0;
