Relation between Fluid mechanics and Thermodynamics
The discussion focuses on the relationship between fluid mechanics and thermodynamics, specifically exploring whether there are valid formulas that apply to both fields due to their shared basis in the flow of substances. Participants examine various equations and principles that may bridge these two areas of study.
  • Some participants suggest that the Navier-Stokes equations relate forces in fluids to their acceleration, which may allow for the application of thermodynamic equations once flows are known.
  • Others argue that fundamental laws, such as the first and second laws of thermodynamics and Newton's second law, can be reformulated for control volume analysis in fluid systems, indicating a potential overlap.
  • One participant mentions the conservation of mass, momentum, and energy as key equations that can be expressed in both differential and integral forms, although they refrain from providing specific formulas.
  • Another participant provides links to resources for the integral and differential forms of the momentum and continuity equations, while expressing uncertainty about the differential form of the energy equation.
  • There is a mention of using minimum entropy generation as a principle in deriving empirical forms of convection expressions, suggesting a connection to thermodynamic concepts.
Participants do not reach a consensus on a specific formula that applies to both fields, and multiple competing views regarding the applicability of various equations remain present throughout the discussion.
Some participants note that the information derived from fundamental laws may not always be useful, indicating a limitation in practical application. Additionally, there are references to specific texts that may provide further insights into the topic.
Prasant
Is there any valid formula which can apply to both thermodynamics and fluid mechanics, as they are both based on the nature of flow of a substance? If yes, please mention the formula and it's derivation?
Science news on Phys.org
I’m not sure what you’re looking for. The Navier-Stokes equations relate the forces (pressure, and shear) in the fluid to the acceleration of the fluid. Knowing the acceleration you can get the flows. The lost energy generates heat and entropy so you should be able to apply the thermodynamic equations once you know the flows.
um, sure. Any fundamental law can be applied to any situation if applied correctly. However, the information you can get from those laws may not be very useful.
The 1st and 2nd laws of thermodynamic as well as Newtons second law can be written in a slightly more general form to allow an easy Control Volume analysis of a fluid system.
For example the 1st law of thermodynamics can be written in the following form:
[tex]\frac{d}{dt}\int_{CV}e \rho dV + \int_{CS}(h+\frac{1}{2} V^2 + gz)(\rho \hat{u}_{\\rel} \cdot d \hat{A}) = \dot Q_{into CV} + \dot W_{other,on CV}[/tex]
And while it may look different than what you may have learned in Thermodynamics it is the same, just written in a form which makes it a bit easier to understand in the context of a fluid mechanics course.
Material flow: conservation of mass, conservation of momentum
Nonmaterial flow: conservation of energy.
Those three equations can be written in either a differential way or integral (much like h2oski1326) way. One can also institute "jump conditions" across material or nonmaterial bounderies.
I'm not going to write any formulas- it would take too much time, and there's no need. My go-to book for all this is "Interfacial Transport Phenomena" by Slattery. Brenner and Edwards "Macrotransport Processes" is also very good.
The integral form of the equations can be found here:
http://en.wikipedia.org/wiki/Reynolds_transport_theorem
The differential form of the momentum equation is the Navier-Stokes equations:
http://en.wikipedia.org/wiki/Navier-Stokes_equations
http://en.wikipedia.org/wiki/Navier-Stokes_equations/Derivation
The differential form of the mas equation is the continuity equation found here:
http://en.wikipedia.org/wiki/Continuity_equation#Fluid_dynamics
I cannot find the differential form of the energy equation. I expect it to look something like equation[/url]
I presume equations involving entropy would be redundant but I came across a paper before which used minimum entropy generation as a principle for deriving empirical forms of convection expressions from computation fluid dynamic techniques.
  • · Replies 42 ·
  • · Replies 16 ·
