Solving Trig Problem: 4 Tangent Circles, Find Shaded Radius
The discussion revolves around a trigonometric problem involving four mutually tangent circles, specifically focusing on finding the radius of a shaded circle among them. Participants explore various geometric relationships and configurations related to the circles, with a mix of theoretical reasoning and practical considerations.
  • Some participants note that there are two shaded circles and clarify which one is being referred to.
  • One participant suggests examining the triangle formed by the centers of the three smallest circles to derive relationships between their radii.
  • Another participant proposes labeling the circles and using right triangles to establish relationships between the radii, but later retracts this approach due to misinterpretation of the geometry.
  • Several participants argue that the problem lacks sufficient information to determine a unique solution, citing the potential for multiple configurations of the larger circle based on the given radii of the smaller circles.
  • One participant suggests that if the three inner circles are identical, the problem could be simplified to finding the radius of the outer circle based on geometric properties of equilateral triangles.
  • Another participant challenges the notion that a unique solution exists, emphasizing that different configurations can yield different results for the radius of the shaded circle.
  • There is a discussion about the relationships between the sides of a triangle formed by the radii and how they relate to the potential solutions for the radii of the circles.
  • One participant expresses uncertainty about whether the problem can be solved if restated with disjoint circles and suggests that proportional relationships may exist.
  • Another participant illustrates a visual analogy to demonstrate the flexibility of the larger circle's radius based on the positions of the smaller circles.
  • Towards the end, participants discuss the uniqueness of solutions given specific triangle side lengths formed by the radii, with some asserting that there is only one solution under certain conditions.
Participants generally disagree on whether the problem can be solved as stated, with some asserting that more information is needed while others explore the implications of assuming identical circles. The discussion remains unresolved regarding the uniqueness of solutions and the conditions necessary to determine the radius of the shaded circle.
Participants highlight the limitations of the problem, noting that without additional information about the larger circle or specific configurations, multiple valid diagrams could yield different answers for the radius of the shaded circle.
Hollywood Dave
Trig Question
Any ideas on solving this problem? The question reads...
Four mutually tangent circles are shown. Find the radius of the shaded circle. See attachment.
Any help will be appreciated. :confused:
Mathematics news on Phys.org
Not to be a buzzkill, but there are two shaded circles. You mean the smallest circle?
Happy thoughts
Rachel
Trig never held my attention for very long, but perhaps your answer will come from looking at the triangle formed by the origins of the three smallest circles?
Happy thoughts
Rachel
Label the circles in increasing size A, B, C, so that circle C has radius=42.6.
Denote the origin of circle N by O_N. Denote the point where two circles N and M intersect by I_NM. Denote the radius of circle N by r_N.
Point O_A and I_BC *look* like they lie on the same line, which would be tangent to circles B and C. Assuming you can prove this, you can consider triangle O_A O_B O_C as two right triangles;
Triangle O_A I_BC O_B and triangle O_A I_BC O_C.
Then note that line O_A O_B, a hypotenuse, is the sum of r_A and r_B. Similarly line O_A O_C = r_A + r_C.
Plug all this info into the two equations for the right triangles and you may get somehwere.
Hope this helps.
Happy thoughts
Rachel
Looks can be deceiving... you cannot form the right triangles as I thought. I also misspoke, as O_A and I_BC lie on some line, of course, but this line is not tangent to circles B and C.
Still happy thoughts
Rachel
As it stands there isn't a solution to this question. You need to provide more information. Proof: just draw the two circles whose radii are given. pick one point on each circle. draw in the normal lines at thos points. where they intersect is the centre of a larger circle tangential to these two. draw it. you are then claiming that the circle you can inscribe that is tangential to all three is uniquely determined which is not the case, I believe.
well if you are talking about the outer circle, combine the two innner blue circles diameter using the radius to find the radius of the large blue circle...
but you are assuming that the centres of the smaller lie on diameter of the larger, which we don't know to be true, indeed we know it might not be true.
If all 3 inner circles are identical, i.e., if they have equal radii, then the problem can be solved, yes?
It becomes three identical isosceles triangles whose bases are connected to form an equilateral triangle. The radius of the outer circle is then the sum of the height of one isosceles triangle and the radius of the circle inscribed in the equilateral triangle.? If you have a way to find the radius of said inscribed circle, the problem is solved?
Then does the original problem not become a matter of proportion or ratio? Sorry, do you understand what I'm trying to say?
Rachel
"If all 3 inner circles are identical, i.e., if they have equal radii, then the problem can be solved, yes?" trivially, since we know what the radius is.
It isn't a matter of proportion or ratio in any obvious sense as i believe i just proved that there is no answer to the question as stated.
Because you can inscribe two such circles, one on each side of the point of tangency of the two given inner circles? If this is why, I don't see why it matters- both of these new circles are still uniquely determined? So there are two solutions. Or did I miss something?
Rachel
the point is that we do not know anything about the larger circle that determines the smaller one, there are an infinite number of diagrams that look like the one given with those two radii that all yield different answers for the radius of the smaller one. Or did I miss something myself about the diagram? I don't believe I did. If there were one mor bit of information, such as the larger circles radius then it would be solvable, but we aren't told what that is nor are we given any information which allows us to decide what it is. there are an infinite number of larger circles one could draw, one for each pair of points on the two given sized ones with the obvious exceptions. Don't believe me? draw to little ones and draw the larger one so it touches at the oppsite sides to where the two small ones touch. ie its centre lies on the same line as the centres of the smaller one. see what happens there? No imagine that if the circles look like this: oo that you draw the degenerate case where the large circle has infinite radius, that is it is a straight line across the top. see how big the third cricle you inscribe is? there is no way of answering the question explicitly. you can form a relationship between the radii of the large circle and the third one inside and one more bit of information would provide an answer but currently it cannot be done.
Ohhhh... I see. Thanks for being patient.
Though I'm not satisfied that the problem cannot be solved if restated as three mutually tangent- um disjoint?- circles, that is, no circle contains another. I still think these must follow some proportional rule. I will work on this, noting that their origins form a triangle and so (r_1+r_2)+(r_1+r_3)>(r_2+r_3) and so on.
Happy thoughts
Rachel
sorry, but you shouldn't waste your time on that: given any two the third can take on any other radius, within reason. they can't be tangential and disjoint by the way. here's how to see it visually, perhaps.
just fix two circles both of radius 1 touching like: oo. now imagine balancing any sized hoop on top of them. suppose also that you've got a really big lassoo that has a stiff circular end. loop it over the whole lot and jiggle it until it lightly touches all three. see, you can do that for all possible hoops you put on top whenever it's top sticks out above the oo ones. if there were some relation ship between the three interior ones then i couldn't do that. there is a relationship between the hoop and top and the size of the lasso, but exactly what I'm not sure.
(Okay, I need to say something- I kind of feel bad because I am asking questions that I could probably figure out on my own with some effort- I should be able to figure them out anyway. But I enjoy this, and think it is beneficial to all, but if this is not what the forum is intended for, then someone needs to tell me so, otherwise I'll proceed.)
Given our 3 circles, their radii r_1, r_2, and r_3 form a triangle with sides (r_1+r_2), (r_2+r_3), and (r_1+r_3). How many solutions {r_1, r_2, r_3} are there for our mutually tangent circles?
Ex. for a triangle with sides 4, 5, 5, one solution is {2, 2, 3} are there any others?
Rachel
I think this is the relationship I was trying to pinpoint.
I believe you're asking gieven the sides of the triangle a b and c, then letting r,s,t be the desired radii, can we solve:
r+s=a
s+t=b
t+r=c
the answer being yes. and it is unique
I think there are is only one solution.
Given the equations
r_1+r_2=a
r_2+r_3=b
r_1+r_3=c
if we change one r, the equations change thusly
(r_1+n)+(r_2-n)=a
(r_2-n)+(r_3+n)=b
(r_1+n)+(r_3+n)=c -> not true.
If we increase(decrease) one radius by some amount, we must decrease(increase) the corresponding radius by the same amount so as not to alter the lengths of the sides of the triangle. And since we are dealing with 3 radii, this is not possible, as one radius ends up having two different lengths.
Happy thoughts
Rachel
Matt, seems I was writing while you were ;)
So back to the original problem... to simplify things, note 28.4*1.5=42.6, so we have r_1=1, r_2=1.5, and r_3.
1+r_3>1.5 and 1+1.5>r_3
2.5>r>.5
yes?
Rachel
This is true of the other origins as well- the line from the origin to the opposite point of tangency does not form a right angle. Thus r_3 does not equal r_1 or r_2, because either would create an isosceles triangle, and opposite points would bisect opposite sides, at their points of tangency, creating right angles. Yes?
In order for the solution to be unique, I have to assume something that is apparent from the diagram, but not stated, i.e. the center of the outer circle is on the line connecting the two given inner circles. Undet this assumption, the problem can be solved using the law of cosines.
Let r and R be the given radii of the two inner circles (28.4 and 42.6).
Let s be the radius of the outer circle, s=r+R.
Let x be the radius of the unknown circle.
Notation p=center of r circle, P=center of R circle, c=center of s circle, q=center of x circle.
We will look at triangles (1) pPx, (2) psx. Apply law of cosines for both triangles, angle A at p.
(1) (R+x)2=(r+x)2+(R+r)2-2(r+x)(R+r)cos(A)
(2) (s-x)2=(r+x)2+R2-2(r+x)Rcos(A)
Going through the algebra, cos(A) can be eliminated between the 2 equations and alll the x2 terms drop out and we get:
x=rRs/(r2+R2+rR).
Good luck (I hope I don't have any typos.)
  • · Replies 59 ·
232K
