Is the Set of Positive Ordered Pairs Closed Under Scalar Multiplication?
The discussion revolves around determining whether the set V, consisting of all ordered pairs of real numbers (x,y) where x>0 and y>0, is closed under the operations of addition and scalar multiplication. Participants explore the implications of scalar multiplication on the elements of the set.
  • Participants discuss the closure of the set under addition and scalar multiplication, questioning the validity of using specific values for x, y, and c. There is an exploration of the consequences of using negative scalars and the conditions that must be satisfied for closure.
Some participants have provided guidance on the necessity of demonstrating closure for all possible values rather than specific examples. There is an ongoing examination of the implications of scalar multiplication on the positivity of the ordered pairs, with some participants noting that negative scalars lead to results outside the defined set V.
Participants are operating under the constraints that x and y must remain greater than zero, which is central to the discussion of closure under scalar multiplication. There is mention of textbook answers that suggest closure is not satisfied, prompting further inquiry into the reasoning behind this conclusion.
aznkid310
[SOLVED] Closed real vector spaces
Determine whether the given set V is closed under the operations (+) and (.):
V is the set of all ordered pairs of real numbers (x,y) where x>0 and y>0:
(x,y)(+)(x',y') = (x+x',y+y')
and
c(.)(x,y) = (cx,cy), where c is a scalar, (.) = multiplication
To show if they are closed or not, i know that i must satisfy a set of conditions such as:
u(+)v = v(+)u
u(+)0 = u
c(.)(u+v) = c(.)u(+)c(.)(v)
et...
I also know that (x,y)(+)(x',y') = (x+x',y+y') is closed but c(.)(x,y) = (cx,cy) is not. So how do i show this? Just use arbitrary numbers?
I tried plugging in x = y = c = 1 for simplicity, but if i do that, it shows that both are closed
Why not try c=(-1)? There aren't any restrictions on the values of c, except that it's a scalar.
if i do that, c(.)(x,y) = (-1,-1) = -2, which is the same as (cx,cy) = (-1,-1) = -2. But the answers are suppose to be different
and
u(+)v = v(+)u
u(+)0 = u
et...
In what sense is "(-1, -1)= -2"? These are operations on pairs of real numbers. I see nothing there that says you are to add the two components.
You said that "c(.)(x,y) = (cx,cy)". Why do you then say "they are supposed to be different"?
And exactly why do you believe that this set is not closed under the defined scalar multiplication?
No, you do not "just use arbitrary numbers". You have to show that they are true no matter what numbers you use.
To show that the set is "closed under addition", you need to show that (x, y)(+)(a,b) is also in the set: in other words, you need to show that (x+ a, y+ b) is an "ordered pair of real numbers".
To show that the set is "closed under scalar multiplication", you need to show that c(.)(x, y)= (cx, cy) is an "ordered pair of real numbers".
The point is the (-1).(x,y) for x>0 and y>0 is (-x,-y). -x and -y are negative. (-x,-y) is not in V.
So to show that c(.)(x,y) = (cx,cy) is in v, then they must satisfy the fact that x and y must be greater than zero no matter what c is?
Btw, I know that c(.)(x,y) = (cx,cy) is not in V b/c that's what the answer is in the back of the book
Yep. I will confess that I didn't notice the "x> 0, y> 0" at first!
That's not a very good answer! It would be better to say "I know that c(.)(x,y)= (cx, cy) is not in V, for all c, because if c= -1 (as Dick suggested) -1(.)(x, y)= (-x, -y) and since x> 0, -x< 0".
  • · Replies 69 ·
12K
