Taylor's Formula in Higher Dimension/Higher order Total differentials
The discussion revolves around applying Taylor's formula in higher dimensions, specifically for the function f(x,y) = x^2 + xy + y^2. Participants are tasked with expressing this function in terms of powers of (x+1) and (y-1) and then writing the Taylor's formula at the point a = (1,4) with p = 3.
  • Participants express uncertainty about how to rewrite the function in the required form and consider using the binomial theorem or substitution methods. There is also discussion about evaluating the n-order total derivative and the application of Taylor's formula.
Some participants have made progress on the first part of the problem, while others seek clarification on the relationship between their findings and Taylor's theorem. There is an ongoing request for resources or examples related to evaluating higher-order total differentials.
Participants are navigating the complexities of higher-order derivatives and the specific requirements of the homework, including the need to evaluate derivatives at a given point and the implications of using different substitution methods.
sinClair
First write f(x,y) = x^2 + xy + y^2 in terms of powers of (x+1) and (y-1)
Then write the taylor's formula for f(x,y) a = (1,4) and p=3
We write taylor's formula as:
f(x) = f(a) + sum[(1/k!)*D^(k)f(a;h)] + (1/p!)D^(p)f(c;h) where sum is from k=1 to p-1 and D^(k)f(a;h) is the kth total differential of f at a evaluated for change h=x-a.
I'm not sure how to do the first part--I thought perhaps I could divide f(x,y) by x+1 or use the binomial theorem. Is there a calculational method to do this?
For the second part, By just plugging into Taylor formula I have f(x,y) = 3 + D^(1)f(a;h) +1/2D^(2)f(a;h) + 1/6D^(3)f(c;h)
The problem is I'm not sure how to evaluate the n-order total derivative D^(n)f(a;h). For n=1, I thought Df(a;h) = df(a)/dx*h + df(a)/dy*k = h/2 + k/4.
Is this calculation right? Can someone help me with the evaluating of the total derivative?
Yes, it is the Taylor's formula you give above! However I suspect you are supposed to use the "less sophisticated" method of taking u= x-1, v= y-1 so that x= u+1, y= v+1 and substituting. After you have it in terms of u and v, replace u with (x-1) and v with (y- 1).
Thanks Ivy I got the first part, though I'm not exactly sure how that relates to taylor's theorem.
I couldn't see what you wrote for the second quote--mind repeating what you said?
Can someone post a link to evaluating higher order total differentials or show how to do it?
