Calculating Weight of Truck on Ferry Boat
The discussion revolves around calculating the weight of a truck that causes a ferry boat to sink a certain distance in water. The problem involves concepts of buoyant force and fluid displacement, situated within the context of physics related to buoyancy and weight measurement.
  • The original poster attempts to apply the principles of buoyancy to determine the weight of the truck based on the volume of water displaced by the ferry boat. Some participants question the distinction between weight and mass in the context of the problem.
Participants have engaged in a productive exchange, with one confirming the calculations presented by the original poster. There is acknowledgment of potential discrepancies in how answers may be interpreted by automated systems.
There is mention of a possible misunderstanding regarding the expected format of the answer, specifically whether weight or mass is required, which may affect grading in an online system.
Lunar Guy
[SOLVED] buoyant force
1. A ferry boat is 4.0 m wide and 6.0 m long. When a truck pulls onto it, the boat sinks 4.00 cm (0.04 m) in the water. What is the weight of the truck?
2. F(sub: B) = F(sub: g)[displaced fluid] = m(sub: f)g
(magnitude of buoyant force = weight of the fluid displaced)
F(sub: B) = F(sub: g)[object] = m(sub: o)g
buoyant force = weight of floating object
m = ρV
(mass = density × volume)
3. Well, the volume of the boat is (4.0 m)(6.0 m)(0.04 m) = (0.96 m³); I mean, the volume of the displaced water is that. ;)
Density of fresh water = 1.00 × 10³ kg/m³
F = ρV(g)
F = (1.00 × 10³ kg/m³)(0.96 m³)(9.81 m/s²)
F = 9.4 × 10³ N
Am I correct?
Correct - and an extra bonus point for quoting the weight of the truck not it's mass.
Although you will probably get the answer marked wrong by some dumb online marking system that expects mass.
All right! Thanks. :)
Problem solved!
EDIT: Ermmm... How do I mark it solved?
Found it. :)
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 65 ·
