What is the acceleration of block B?
  • Thread starter Thread starter TS656577
    Blocks Friction
The problem involves three blocks connected by cords over frictionless pulleys, with specific masses given for each block. The goal is to determine the acceleration of block B, while also considering the dynamics of block A and block C.
  • Exploratory, Assumption checking
  • Participants discuss treating the blocks as separate problems and consider the forces acting on each block. There is an exploration of how to relate the accelerations of the blocks, with some questioning the signs in their equations.
Participants are actively engaging with the problem, with some offering insights into the relationships between the blocks' accelerations. There is a recognition that the acceleration of all blocks may be the same, but no consensus has been reached on the specific values or signs in the calculations.
One participant notes the requirement to find the acceleration of block A, which adds complexity to the discussion. There is also mention of the need to clarify the signs in the equations being used.
TS656577
[SOLVED] Friction and blocks
Three blocks are attached by cords that loop over frictionless pulleys. Block B lies on a frictionless table; the masses are mA=6kg, mB=6kg, and mC=18kg. The acceleration due to gravity is g.
F=ma
I thought that it would be wise to treat these as two separate problems. I thought I would solve one side by the following. Block B T=ma Block C F(g)-T=ma and thus mg-T=ma
I thought that to figure out the acceleration of block B (since we know C's is -9.8m/s^2) that i would use the equation a(B)=(m(C)g - (m(C)g))/m(B) But when I do that i would get 0/6. That can't be right because the block C would move because it is heavier than block A
A acts in the opposite direction to C so you could think of it as a negative weight on the same side as C. That will simplify it into a single falling block pulling on B.
Oops, i forgot to mention, i have to find the acceleration of block a. So would i still be on the right track? I feel like my signs are messed up in that equation i had
Since they are all on the same wire the accelaration of all the blocks is the same.
so the acceleration of block A is +9.8 m/s^2?
or are you saying that once i figure out the acceleration of one block, then that would be the same for all of them
  • · Replies 33 ·
