C^n and R^n: Are They Compact?
  • Thread starter Thread starter pivoxa15
    Compact
The discussion revolves around the compactness of the spaces C^n and R^n, with participants exploring definitions and implications of compactness in a topological context.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the implications of being unbounded on compactness, with references to open covers and the Heine-Borel theorem. Questions arise regarding the definitions of compactness and the role of boundedness.
The conversation is active, with various interpretations of compactness being explored. Some participants provide definitions and examples, while others question the assumptions made about the spaces in question.
There is mention of constraints regarding definitions of compactness, particularly in relation to the use of norms and the generality of the definitions being applied. The discussion hints at differing expectations based on the source material referenced by participants.
pivoxa15
Is C^n or R^n compact?
They are not bounded so can't be compact.
Right. Of course you can also exhibit an infinite open cover with no finite subcover, namely {B_n : n>=1}, where B_n={x:|x|<n} is the open ball centered at 0 of radius n.
What does your example mean? That C^n or R^n could be compact?
No...
What does it mean then?
Hmm. I take it by "compact" you mean "closed and bounded"? This isn't the most general definition of compactness, which usually goes as follows: a topological space X is compact if every collection of open sets whose union is X has a finite subcollection whose union is still X (more succinctly put: if every open cover of X admits a finite subcover). In R^n and C^n with their standard topologies, it's a theorem (Heine-Borel) that this definition is equivalent to "closed and bounded"; in a general metric space this can be adapted to "complete and totally bounded".
So what I did in my post was exhibit an open cover of R^n (and C^n) that doesn't have a finite subcover, which means (by the general definition) that they're not compact.
Is C^n/{0} compact? How about R^n/{0}?
Why do you have doubts?
Those spaces are unbounded so they must not be compact even after deleting a fintie number of zeroes.
Pivoxa15, your definition of compactness is not the most general one. It relies on defining what a bounded set is , which in turn relies on some concept of "size". This is generally done by using norms but sometimes you don't have a norm to work with.
The hierarchy of spaces is as follows: Inner product spaces < Normed Spaces < Metric Spaces < Topological Spaces, where "A<B" means that the type of Spaces "A" induces a type of space B but there are spaces of type B that are not of type A. For example, there is a method to determine if a norm could be generated from an inner product. It is called the "polarization identity". Look it up.
With this in mind, I would say that the problem you posted is not as trivial as saying "it's not bounded" if the definition you are supposed to use is the general one (but still, it's not that much of a difficult problem).
Or you could use the extra structure you know there is on C^n or R^n and the Heine-Borel theorem. As long as you mention that, not bounded is quite enough, even if you're working with the open cover definition.
yes , but I'm sure he was using books where you're not supposed to assume the extra structure :)
