Prove Vector Projections Perpendicular in R3
  • Thread starter Thread starter tony873004
    Projections Vector
The discussion focuses on proving that the vector difference \(\overrightarrow{w} - \text{proj}_{\overrightarrow{v}} \overrightarrow{w}\) is perpendicular to the vector \(\overrightarrow{v}\) in \(\mathbb{R}^3\). The projection formula used is \(\text{proj}_{\overrightarrow{v}} \overrightarrow{w} = \frac{\overrightarrow{v} \cdot \overrightarrow{w}}{|\overrightarrow{v}|^2} \overrightarrow{v}\). The key conclusion is that demonstrating the dot product \(\overrightarrow{v} \cdot (\overrightarrow{w} - \text{proj}_{\overrightarrow{v}} \overrightarrow{w}) = 0\) confirms the perpendicularity. An alternative approach is suggested for simplification.
  • Understanding of vector operations in \(\mathbb{R}^3
  • Familiarity with the concept of vector projection
  • Knowledge of dot product calculations
  • Basic grasp of linear algebra principles
  • Study vector projections in detail, focusing on geometric interpretations
  • Learn about the properties of dot products and their applications in geometry
  • Explore alternative methods for proving vector relationships in linear algebra
  • Investigate the implications of perpendicular vectors in higher dimensions
Students and professionals in mathematics, physics, and engineering who are working with vector analysis and linear algebra concepts.
tony873004
Let [tex]\overrightarrow v[/tex] and [tex]\overrightarrow w[/tex] be vectors in R3. Prove that [tex]\overrightarrow w - {\rm{proj}}_{\overrightarrow v } \overrightarrow w[/tex] is perpendicular to [tex]\overrightarrow v[/tex] .
Here's my attempt:
[tex]\begin{array}{l}<br /> \left( {\overrightarrow w - {\rm{proj}}_{\overrightarrow v } \overrightarrow w } \right) \cdot \overrightarrow v \mathop = \limits^? 0 \\ <br /> \\ <br /> {\rm{proj}}_{\overrightarrow v } \overrightarrow w = \frac{{\overrightarrow v \cdot \overrightarrow w }}{{\left| {\overrightarrow v } \right|^2 }}\overrightarrow v \\ <br /> \\ <br /> \overrightarrow v \cdot \overrightarrow w = v_1 w_1 + v_2 w_2 + v_3 w_3 \\ <br /> \\ <br /> \left| {\overrightarrow v } \right| = \sqrt {v_1^2 + v_2^2 + v_3^2 } \\ <br /> \left| {\overrightarrow v } \right|^2 = v_1^2 + v_2^2 + v_3^2 \\ <br /> \\ <br /> \frac{{\overrightarrow v \cdot \overrightarrow w }}{{\left| {\overrightarrow v } \right|^2 }} = \frac{{v_1 w_1 + v_2 w_2 + v_3 w_3 }}{{v_1^2 + v_2^2 + v_3^2 }} = \frac{{v_1 w_1 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_2 w_2 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_3 w_3 }}{{v_1^2 + v_2^2 + v_3^2 }} \\ <br /> \\ <br /> \frac{{\overrightarrow v \cdot \overrightarrow w }}{{\left| {\overrightarrow v } \right|^2 }}\overrightarrow v = \left( {\frac{{v_1 w_1 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_2 w_2 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_3 w_3 }}{{v_1^2 + v_2^2 + v_3^2 }}} \right)\left\langle {v_1 ,\,v_2 ,\,v_3 } \right\rangle \\ <br /> \\ <br /> \,\,\,\,\,\,\,\,\,\,\,\,\,\, = \left( {\frac{{v_1 w_1 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_2 w_2 }}{{v_1^2 + v_2^2 + v_3^2 }} + \frac{{v_3 w_3 }}{{v_1^2 + v_2^2 + v_3^2 }}} \right)\left\langle {v_1 ,\,v_2 ,\,v_3 } \right\rangle \\ <br /> \end{array}[/tex]
Things are starting to get real ugly. Am I missing an easier way?
Yes, you are. You want to show v.(w-(v.w)*v/(v.v))=0. Just multiply the outer dot product through.
