Linear Algebra : prove geometric multiplicities are the same
The discussion revolves around proving that similar matrices A and B have the same geometric multiplicities for their eigenvalues. The original poster seeks assistance in understanding the relationship between the eigenvectors of A and B, given their similarity.
  • Participants explore the definition of geometric multiplicity and its relation to eigenspaces. There is a suggestion to demonstrate that eigenvectors of B can be expressed in terms of those of A using the similarity transformation. Some participants also question whether showing the characteristic polynomial suffices for proving the equality of geometric multiplicities.
The discussion is ongoing, with participants providing insights into the relationship between eigenvectors and eigenspaces. There is a recognition that while the characteristic polynomial indicates shared eigenvalues and algebraic multiplicities, it does not directly address geometric multiplicities.
Participants note that the properties of similar matrices must be considered, and there is an emphasis on the definitions and implications of geometric versus algebraic multiplicities.
braindead101
Let A and B be similar matrices. Prove that the geometric multiplicities of the eigenvalues of A and B are the same.
Some help I have gotten so far but still don't know how to proceed from there:
To prove that the geometric multiplicities of the eigenvalues of A and B are the same, we can show that, if B = P^-1 AP , then every eigenvector of B is of the form P^-1 v for some eigenvector v of A.
And i also know that for A and B to be similar matrices, these 5 properties must hold.
1. det A = det B
2. A and B have the same rank
3. A and B have the same characteristic polynomial
4. A and B have the same eigenvalues
5. A is invertible iff B is invertible
any help would be greatly appreciated
The "geometric multiplicity" of an eigenvalue is the dimension of the "eigenspace" (subspace of all eigenvectors) for that eigenvalue.
Now, are you saying that you can use the fact that "if B = P^-1 AP , then every eigenvector of B is of the form P^-1 v for some eigenvector v of A" or do you have to prove that (it's very easy)? If you can use that, then there is an obvious one-to-one correspondence. In particular, you can show that If [itex]{v_1, v_2, ..., v_n}[/itex] is a basis for the eigenspace of A, corresponding to eigenvalue [itex]\lambda[/itex], then [itex]P^{-1}v_1, P^{-1}v_2, ..., P^{-1}v_n}[/itex] is a basis for the eigenspace of B, corresponding to that same eigenvalue.
To show that I think it might be sufficient to show that these two matrices (since they're similar) have the same characteristic polynomial. So...
There's an invertible matrix P such that
A= ((P^-1) B P)
det(A-tI)
det([P^-1 BP]-tI)
det([P^-1 BP]-[P^-1tI P])
det([P^-1(B-tI) P])
det(P^-1 P) det(B-tI)
= det(B-tI)
A= ((P^-1) B P)
det(A-tI)
det([P^-1 BP]-tI)
det([P^-1(B-tI) P])
= det(B-tI)
Sharing the same characteristic polynomial only tells you the eigenvalues and algebraic multiplicities are the same. It tells you nothing about geometric multiplicity or eigenvectors.
  • · Replies 25 ·
  • · Replies 24 ·
