What type of water pump is typically used in fountains?
  • Thread starter Thread starter yoran
    Pump Water
The discussion revolves around the types of water pumps typically used in fountains, focusing on their properties and applications in water features. Participants explore different pump technologies and their suitability for various fountain designs.
  • Some participants mention two main types of pumps: centrifugal pumps and positive displacement pumps, noting that both can be used in fountains.
  • One participant clarifies that water feature fountains typically use centrifugal pumps, which operate by spinning an impeller to generate flow and pressure.
  • It is suggested that submersible pumps are suitable for simple fountain features, while self-priming or dry well pumps are recommended for installations involving aquatic life due to potential oil contamination from submersible pumps.
  • Another participant expresses confidence that centrifugal pumps are preferred due to their efficiency in providing flow relative to size, while also noting the importance of matching the pump to system head requirements.
  • There is acknowledgment of trade-offs between centrifugal and positive displacement pumps, with positive displacement pumps offering more flexibility in pressure delivery.
Participants generally agree that centrifugal pumps are commonly used in fountain applications, but there is some discussion regarding the advantages and disadvantages of different pump types, indicating that multiple views remain on the best choice for specific scenarios.
Participants discuss the operational principles of pumps and their suitability for different fountain designs without resolving the specific conditions under which each type is preferable.
This discussion may be useful for students studying system theory, professionals in fountain design, and individuals interested in water feature installations.
yoran
Hello,
For the course "System Theory" I'm following, I have to identify systems in every day life and explain some of its properties (input, output, internal variables, internal parameters,...). I thought a fountain was a good idea for such a system. The problem is I don't know what water pumps are typically used in fountains. I've found a list of different "technologies" for pumps but I need to know which one is used for fountains (or any "water-lifting" device).
I hope someone can help me.
Thanks
There are two types of pumps:
*Centrifugal Pumps (Axial flow pumps, Radial flow pumps and combination off this two)
*Positive displacement pumps
You can use both types for the fountains.
Fountain pumps
Hi, I am assuming you mean a water feature type fountain? Not a drinking water fountain as one may find in a park or office/factory rest area?
Water feature fountains have one of two types of pumps installed in general. They both operate using the centrifugal principle which is simply a spinning impeller (disk with vanes either open or closed on both sides. The impeller "throws" the fluid from centre of the impeller throat to the outside diameter, this centrifugal force and the resultant flow/pressure generated will determine the power required by the pump to achieve your desired result in terms of flow and head. Our site us currently building but if you go to the front page and navigate to where it says how to select a pump, I think we have soe useful information there. As I said the site is building so we will be adding information as we grow it. Your comments will be greatly appreciated so we can generate quality content.
For a fountain one would use either a submersible pump for a simple feature, or a self priming or dry well type installation for a pond or feature that has fish and other aquatic life. The reason you would not use a submersible in a feature with live organisms is because the submersible will generally have an oil chamber to lubricate the seals. If a seal pops you will have oil on the water surface which will suffocate all life.
Our site is http://www.pedrollopumps.com should you wish to check it out.
Here is a more defined link http://www.pedrollopumps.com/images/howtoreadapumpcurve.html
I hope this helps you in some way. Please feel free to request further information or ask other questions in this regard.
Evan Lewis
CEO Pedrollopumps.com
I am 99% positive that they will utilize a centrif pump set up. Centrifs will give you more flow for the size than you will get from a P.D. However, with centrifs, you have to be careful to match your pump to your particular system head requirements. In cases like this, the system demands and requirements will usually never change. P.D.s allow you more flexibility in that regard and can deliver higher pressures. It's always a trade off.
Thanks a lot for all your replies! I looked up some info about centrifugal pumps and it definitely helped me with my homework assignement. Thanks a lot guys!
NO Problem Hope the info helped
Hope you have found enough info.
Regards
Evan
  • · Replies 29 ·
11K
  • · Replies 16 ·
