Equivalent Resistance in partial parallel/series cicuit
The discussion revolves around finding the equivalent resistance between two points in a circuit that includes both series and parallel resistor configurations. Participants are analyzing a specific circuit setup and attempting to apply the relevant equations for series and parallel resistances.
  • Mixed
  • Participants are attempting to reduce the circuit step by step, calculating equivalent resistances for different configurations. There are questions about the correct identification of series and parallel relationships among the resistors.
Some participants have provided guidance on how to approach the problem, suggesting specific steps for combining resistors. There is an ongoing exploration of different interpretations of the circuit layout, with no explicit consensus reached on the correct method for combining the resistances.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also some uncertainty regarding the arrangement of the resistors and how to properly apply the series and parallel equations.
thatgirlyouknow
Find the equivalent resistance between points A and B in the drawing.
Rseries = R1+R2+R3...
Rparallel: 1/Rp = 1/R1+1/R2+1/R3...
Reducing it down:
1/8+1/9 = 1/R1 = 4.235
That's in parallel with 20, so:
1/20+1/4.235 = 3.495 ohms
3, 4, and 6 are in series:
3+4+6 = 13 ohms
Add that to the previous and you have 16.495 ohms, which is incorrect.
Is one parallel and I'm not adding it as such? Or should I combine differently?
Thanks so much!
thatgirlyouknow said:
Reducing it down:
Good. R1 = 4.235 (not 1/R1).
Nope. The 3 ohm resistor is in the way.
So then 20 and 3 are in series, right?
20+3=23 ohms
So now my drawing has:
23 ohms . 4 ohms
4.235 ohms
. 6 ohms
Would the 4 and 6 be considered series?
4+6 are in series
9+8 are in parallel
3 and 20 are not in series!
You need to do this step by step...
6+4 = 10
1/8 + 1/9 = 17/72
now you have
------3 -----------
-20------17/72--10
Next you have 17/72 and 10 in parallel.
1/10+72/17 = 737/170
-- -- 3 -------
-20------737/170
Now the 3 and 737/170 are in series so just add them to get
-20-------1147/170
Now these are in parallel you can solve!
When you added for 17/72 and 10 in parallel, shouldn't it have been 1/4.235+1/10 = 1/R = 2.975?
so then with
------3--------
20 2.975
So now which should I combine first?
first take this and then you shall have the feel of the question much better..""
General rules for doing the reduction process include:
1. Two (or more) resistors with their heads directly connected together and their tails directly connected together are in parallel, and they can be reduced to one resistor using the equivalent resistance equation for resistors in parallel.
2. Two resistors connected together so that the tail of one is connected to the head of the next, with no other path for the current to take along the line connecting them, are in series and can be reduced to one equivalent resistor.
Finally, remember that for resistors in series, the current is the same for each resistor, and for resistors in parallel, the voltage is the same for each one
  • · Replies 27 ·
