How to Find the Acceleration of a Charged Particle in a Uniform Electric Field?
The discussion revolves around finding the acceleration of a charged particle in a uniform electric field, specifically when the particle moves parallel to the field. The original poster presents equations related to velocity and position, seeking clarification on how to approach the problem.
  • Participants discuss the relationship between force, charge, and electric field, questioning the definitions and variables involved. There is uncertainty about the meaning of the variable 'e' and its context within the equations provided. Some participants suggest that the problem may involve relativistic concepts.
The conversation is ongoing, with participants exploring various interpretations of the problem and questioning the assumptions made in the original statement. Some guidance has been offered regarding the relationships between force, velocity, and acceleration, but there is no explicit consensus on how to proceed.
There is mention of the problem being part of an advanced physics course, and participants express confusion over the terminology and the equations provided, particularly regarding the use of 'e' and 'E'.
Clutch Cargo
What is the acceleration of a charged particle in a uniform electric field? Assume the particle moves along a straight line parallel to the electric field. Show that a particle starting from rest at x=0 and t=0 the speed and position are given by the following formulas.
Vx=(eE/m)(t/Sqrt(1+(eEt/mc)^2)
and
x=(mc^2/eE)Sqrt(1+(eEt/mc)^2-1)
I don't know where to start...
what is the force?
I don't know. It is just the "uniform electric field" of unspecified potential. This question is written exactly as it was given to me.
But what course is this?
[tex]\vec{F} = q\vec{E}[/tex], where q is the charge and E the electric field
That formula you must know if someone wake you up in the middle of the night:P
EDIT:
Or w8 a minute, what is the relation between acceleration and veolcity? This must be a course in Newtonian dynamics ;)
(this is not advanced physics, I can't believe someone has this as upper level undergraduate physics..)
Yep, it's advanced physics. And this type of question is not even in the textbook! Another thing that bugs me is the little e. The ONLY mention of the little e in the text is for the rest energy of an electron as being e=.511MeV but looking at the relevant equations I'm given we have mass, time, Energy, velocity, and position (x) and the little e is all that remains to express the electric field which I would expect to be volts per meter. I would say E were the electric field but it is a scalar quantity and the conventions used in my textbook are that the scalar E is always energy.
No the electric field is a vector quantity.
And is this correct?
x=(mc^2/eE)Sqrt(1+(eEt/mc)^2-1) ??
It would reduce to
x=(mc^2/eE)Sqrt((eEt/mc)^2) =(mc^2/eE)(eEt/mc)
q is the electric charge of the particle (in coulombs)
and
E is the electric field (in volts per meter)and it equals...capital E as a scalar!
Problem is there is still the question of what the little e is...
charge of the electron, the elementary charge...
sometimes they use e instead of q..
And you should bewere that since the alphabet is very short in comparison with the number of physical quantities, you must look at the context. An E in an electro magnetism problem is in 99% of the cases the electric field.
This is a special relativity question. From
[tex]\vec{F}=\frac{d\,\vec{p}}{d\,t}\quad (1)[/tex]
with
[tex]\vec{F}=e\,\vec{E}[/tex]
and
[tex]\vec{p}=\gamma\,m\,\vec{u},\gamma=\frac{1}{\sqrt{1-(\frac{u}{c})^2}}[/tex]
Since this is a 1-dimension problem, integrate (1) to get your result.
with
and
why not wait til OP show some work? I already pointed out that he should look at the relation between velocity and acceleration. He must also show how to get to V_x and x
@ malawi_glenn
Is there a general rule on how someone must give instructions? Is it too muh trouble to remind someone the relations that he must apply?
Rainbow Child said:
@ malawi_glenn
Depends on how you see it, the OP MUST show attempt to solution before any help can be recived. And since I already have kicked him in the correct direction by saying that he should look at the relation between veolcity and acceleration and that he should look at relativistic formula. So in fact, I myself broke the forum rules too.
