Path between two points in rolling terrain
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
    Path Points Rolling
The discussion revolves around the existence of a trajectory connecting any two points on a frictionless, smooth terrain, with participants exploring the mathematical and topological implications of the problem. The scope includes theoretical considerations and mathematical proofs rather than purely physical interpretations.
  • Some participants suggest that the question may be more mathematical than physical, questioning the definitions of trajectory and path in the context of the problem.
  • There is a discussion about the nature of connected sets versus path-connected sets, with some participants asserting that a connected set is not necessarily path-connected.
  • A specific example involving an idealized putting green is proposed to illustrate the problem, raising questions about the ability to roll a ball over certain points depending on the terrain's curvature.
  • One participant proposes a more rigorous formulation of the question, relating it to simply-connected, smooth, 2-dimensional metric spaces and geodesics.
  • Another participant expresses interest in the topological aspects of the problem, indicating a lack of familiarity with topology but finding the topic intriguing.
Participants exhibit a mix of agreement and disagreement, particularly regarding the mathematical nature of the problem and the definitions involved. Some participants acknowledge the need for a proof, while others question the assumptions made about trajectories and paths.
There are unresolved definitions and assumptions regarding what constitutes a trajectory and the implications of curvature on the ability to connect points on the terrain.
This discussion may be of interest to those studying mathematics, particularly topology and geometry, as well as individuals exploring the intersection of physics and mathematical proofs.
Loren Booda
Show that there exists at least one trajectory connecting any two points on a frictionless, smooth (albeit curved) terrain.
This actually sounds like more of a mathematics question, a proof even, rather than a physics question. Are you talking about a 2D terrain, a 3D terrain? Is a trajectory a parabola or something? What would constitute a path between two points that is not a trajectory?
I don't understand what you are asking.
A connected set is not necessarily path-connected.
CaptainQuasar
Take for instance an idealized putting green, one without friction or discontinuities, but with any combination of curvatures. Is it always possible to putt from one point on the green so that the ball rolls directly over any other point thereon? I may be overlooking the obvious.
arildno
Would it be in this case?
arildno,
I now understand what you are saying. You are quite right. I withdraw my question.
Ah, I see. So in this case a trajectory is a path that remains in contact with the surface and behaves like a particle with a gravity-like force applied to it? Is this a particular meaning of “trajectory” or am I ignorant of the real definition of that word?
I don't know if this is an answer or a misunderstanding of the problem, but in your putting example if there were any overhangs the golf ball would leave the surface, so in that sort of curved surface there would definitely be points which the golf ball could not roll over.
I'm not making some sort of objection to the problem, as arildno may think, I'm really not understanding it.
I think this is the most rigorous way to state the question:
Given some simply-connected, smooth, 2-dimensional metric space M and a point P on M, does every point of M have a geodesic that also passes through P?
Ah, so as I suspected, this is essentially a topology problem that would require a proof as an answer? I've never studied topology so even if this is a trivial problem I'd have some learning to do to answer it but it looks interesting. Just looking up the words you used was very helpful, Ben. But that's basically what I meant by saying it looks like a math problem instead of a physics problem.
Let's adopt Ben's conjecture. Thanks for your clarity, Ben.
  • · Replies 37 ·
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 23 ·
