Thread Closed
[SOLVED] Force on the sides of a swimming pool, differeniation
Share Thread
Feb16-08, 11:18 AM   #1
TFM
A swimming pool measures a length of 5.7m , width 3.8m , and depth 2.9m. Compute the force exerted by the water against either end. Do not include the force due to air pressure.
I have already calculated the force on the bottom as 6.2*10^5N
Hint: Calculate the force on a thin, horizontal strip at a depth , and integrate this over the end of the pool.
2. Relevant equations
f = pgya
3. The attempt at a solution
pretend the swimming pool is on its end, using formula
f = intergration,/' pgdya
from 0 to 5.7
getting F = 1/2 pg(y^2)a
But this doesn't seem to work?
Any help/suggestions/ideas
TFM
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb16-08, 11:31 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Why doesn't it seem to work?
Edit: I think you need to integrate more carefully.
Feb16-08, 11:44 AM   #3
TFM
I get an answer of 1754395.02, which Mastering physics says is wrong. Any idea where in my integration I have gone wrong?
TFM
Feb16-08, 11:54 AM   #4
Recognitions:
I think I see the problem. Don't turn the pool on its end; that's changing the problem. We want to find the force on either end in its orginal configuration. This will affect a couple of your variables.
Feb16-08, 12:01 PM   #5
TFM
Keeping the Pool in the same way, I get F = 892586.94
However, if i ignore the 1/2 from the integration, I get 1785173.88
Is this the answer, because there are two sides?
TFM
Feb16-08, 12:09 PM   #6
Recognitions:
I don't think so. Can you show how you integrated and what variables you multiplied together to get this result?
Feb16-08, 12:18 PM   #7
TFM
I integrated:
f = intergration,/' p*g*y*a dy
and got
F = 1/2 pg(y^2)a
I then used
p = 1000 (density of water)
g = 9.8
y = 2.9
a = 5.7*3.8
Giving me 892586.94
TFM
Feb16-08, 12:28 PM   #8
Recognitions:
Right away I can tell that the units are off: your units are N-m for a force answer, which is incorrect of course. That's why checking units is so useful is troubleshooting a problem.
I agree with setting force equal to (density)(g)(depth)(area). However, it seems to me that your area should be a rectangular differential element at the end of the pool. This differential element would have a width of w and a height of dy. Does this make sense?
Feb16-08, 12:42 PM   #9
TFM
Quote by Mapes View Post
I'm not sure...? Would it be:
Area = width*length
Area = ,/' width*length dlength
giving area = 1/2 * width*length^2
putting bvack into the equation,
F = pgya
F = pgy(1/2 * width*length^2)
If not, then I'm don't understand, sorry
TFM
Feb16-08, 12:56 PM   #10
Recognitions:
How about [itex]dF=pgy\,da=pgy(w\,dy)[/itex], [itex]F=\int_0^{\mathrm{depth}}dF=\frac{1}{2}pgw(\mathrm{depth})^2[/itex]?
Feb16-08, 01:22 PM   #11
TFM
That makes sense - I was still using the area as being the floor. I now get an answer of 15979, alkthough this is ten times smaller than the force on the floor? (and apparantly isn't the answer)
TFM
Feb16-08, 01:25 PM   #12
Recognitions:
x g?
Feb16-08, 01:38 PM   #13
TFM
x g
D'oh
With g in, gives right answer:
156594.2
Although Mastering Physics only accepts 160000
Thanks, Mapes
TFM
Feb16-08, 01:41 PM   #14
Recognitions:
You're welcome, good luck.
Thread Closed
Similar discussions for: [SOLVED] Force on the sides of a swimming pool, differeniation
Thread Forum Replies
Force on the bottom of a swimming pool Introductory Physics Homework 5
[SOLVED] Optics: Distance of Key in swimming pool Introductory Physics Homework 2
Diving into swimming pool General Physics 18
Refraction in a Swimming Pool. Introductory Physics Homework 3
A swimming pool ... right . General Discussion 6
