Find Critical Points of Hessian Matrix
The discussion revolves around finding critical points of the function f(x,y,z)=x^3+y^2+z^2+12xy+2z and determining their types, specifically whether they are degenerate or non-degenerate, as well as calculating the Morse index for non-degenerate points.
  • Participants present attempts to find critical points by setting the partial derivatives to zero. They discuss the calculation of the Hessian matrix and its determinant for the identified critical points. Questions arise regarding the classification of these points as minimum, maximum, or saddle points, as well as the implications of the eigenvalues derived from the Hessian.
Multiple participants are engaged in verifying calculations related to the critical points and the Hessian matrix. There is an ongoing exploration of the implications of the eigenvalues on the nature of the critical points, with some guidance provided on interpreting the signs of the eigenvalues.
Participants are working under the constraints of homework rules, focusing on the theoretical aspects of critical point classification without providing definitive conclusions about the nature of the points discussed.
azatkgz
Please,check my solution.
Find critical points of the function [tex]f(x,y,z)=x^3+y^2+z^2+12xy+2z[/tex]
and determine their types (degenerate or non-degenerate, Morse index for non-
degenerate).
Attempt
[tex]\frac{df}{dx}=3x^2+12y=0[/tex]
[tex]\frac{df}{dy}=2y+12x=0[/tex]
[tex]\frac{df}{dz}=2z+2=0[/tex]
Critical points are at
x=24 y=-144 z=-1
x=0 y=0 z=-1
[tex]H(f)=\left|\begin{array}{l[cr]}6x&12&0\\12&2&0\\0&0&2\end{array}\right|[/tex]
for x=24
[tex]det\left|\begin{array}{l[cr]}144&12&0\\12&2&0\\0&0&2\end{array}\right|=288[/tex] non-degenerate
for x=0
[tex]det\left|\begin{array}{l[cr]}0&12&0\\12&2&0\\0&0&2\end{array}\right|=-288[/tex] non-degenerate
degenerate).
Attempt
x=24 y=-144 z=-1
x=0 y=0 z=-1
for x=24
for x=0
keep going... are they minimum, maximum.. saddle points??
Morse index
for (0,0,-1)
[tex]det\left|\begin{array}{l[cr]}-\lambda &12&0\\12&2-\lambda &0\\0&0&2-\lambda\end{array}}\right|=0[/tex]
[tex](2-\lambda )(-\lambda(2-\lambda)-144)=0[/tex]
[tex]\lambda_1=2,\lambda_2=1-\sqrt{145},\lambda_3=1+\sqrt{145}[/tex]
for (24,-144,-1)
[tex]det\left|\begin{array}{l[cr]}144-\lambda &12&0\\12&2-\lambda &0\\0&0&2-\lambda\end{array}}\right|=0[/tex]
[tex](2-\lambda )((144-\lambda)(2-\lambda)-144)=0[/tex]
[tex]\lambda_1=2,\lambda_2=73-\sqrt{5185},\lambda_3=73+\sqrt{5185}[/tex]
Is it right?What we can say about maximum,minimum and saddle points?
azatkgz said:
Morse index
for (0,0,-1)
for (24,-144,-1)
i didnt check you're calculus, but find what the sign of eigenvalues mean and you'll get you're answer.
bye
  • · Replies 27 ·
  • · Replies 24 ·
