The space of continuous functions.
The discussion revolves around the compactness of the space of continuous functions, specifically the closed subset F of C(X,Y) where X is a compact space and Y is a compact metric space. Participants explore the implications of various properties such as equicontinuity and completeness in relation to compactness, and they reference the Arzelà-Ascoli theorem and Tychonoff's theorem in their arguments.
  • Some participants propose that proving C(X,Y) is compact would imply F is compact, but others question the validity of this reasoning.
  • One participant mentions a theorem stating that a closed subset of a compact space is compact, suggesting this as a basis for their argument.
  • There is a discussion about the definitions of the compact-open topology and the open-compact topology, with some confusion regarding terminology.
  • Another participant argues that C(X,Y) is not compact, leading to further debate about the conditions required for compactness.
  • Some participants suggest that the condition on F implies equicontinuity, which may lead to the application of the Arzelà-Ascoli theorem to show compactness.
  • There is mention of the relationship between completeness and total boundedness in metric spaces, with some participants asserting that F is absolutely bounded based on the given conditions.
  • One participant highlights the need to show that F is complete and totally bounded to conclude its compactness, referencing the completeness of Y and C(X,Y).
Participants express differing views on the compactness of C(X,Y) and the implications for F. There is no consensus on whether C(X,Y) is compact, and the discussion includes multiple competing viewpoints regarding the necessary conditions for compactness.
Some participants acknowledge potential misunderstandings regarding terminology and the implications of various theorems. There is also mention of the need for rigorous proofs and the challenges posed by the lecturer's teaching style.
MathematicalPhysicist
Let X be a compact space, (Y,p) a compact metric space, let F be a closed subset of C(X,Y) (the continuous functions space) (i guess it obviously means in the open-compact topology, although it's not mentioned there) which satisifes:
for every e>0 and every x in X there exists a neighbourhood U of x s.t for every f in F:
f(U) is a subset of B_e(f(x)) which is an open ball with radius e.
prove that F is compact.
well i want to prove that C(X,Y) is compact and then it will follow that F is compact.
now let U(W(C,U))=C(X,Y) which is an arbitrary covering of C(X,Y), i.e for every C compact in X and every U open in Y s.t f(C) is contained in U.
now i need to find a finite covering, now because Y is compact and metric then it is covered by a finite union of open balls, because f in F is continuous then f^-1(B_e(f(x))
is open in X, so finite union of them cover the entire set X, so because every compact set in X is actually covered by a finite union of f^-1(B_e(f(x))) and also every every open set in Y is covered by a finite union of open balls, then C(X,Y) is covered by a finite union of W(C_i,B_e_j(f(x))) s.t C_i is compact in some f^-1(B_e_j(f(x)) i.e f(C_i) is contianed in B_e_j(f(x))), so C(X,Y) is compact and then also F is compact as beiing a closed subset of C(X,Y).
am i right or way off?
thanks in advance.
How does that follow?
well there's a theorem that if X is a compact topological space and A a closed subset of it then A is compact in X.
What is the continuous functions space? Which one? Define an open set or subbasis element of it?
I've heard of compact-open topology but not open-compact topology. Maybe it's the reverse, but we would have to prove it's a topology first, which I don't think it is.
If X is a topological (or metric) space and M is a metric space, then the set of all bounded continuous functions from X to M forms a metric space if we define the metric as above: d(f, g) = supx in X d(f(x), g(x)) for any bounded continuous functions f and g. If M is complete, then this space is complete as well.
http://en.wikipedia.org/wiki/Metric_space
What can this lead to?
C(X,Y) isn't compact.
instead of telling me I'm wrong, you could have also pointed me to a possible solution, could you not?
anyway, jason, open-compact is the same as compact-open, i just changed the order.
okay, i see it now, thanks jason.
wait a minute gel, if C(X,Y) is metric, and because Y is complete it's also complete, then by the condition given on F, C(X,Y) is absolutely bounded, then by a thoeorem we learned in class, C(X,Y) must be compact, cause a metric space is compact iff it's complete and absolutely bounded (absolutely bounded, or totally, is that there's the metric space has a finite e>0 net.
So what i said is wrong?
just got the wrong terminology on absolutely bounded (should be totally bounded), it's a problem that you learn the terms in hebrew and after you look at the definitions in munkres with the theorems. (the lecturer is awfull, an entire lecture today was only with figures, with no formalism, and a lot of handwaving of the worst kind, we learned on manifolds, a topic which he didn't prove anything in it rigorously).
It is wrong. You can't conclude that C(X,Y) is totally bounded based on what you're given. What you could try to do is prove that F is totally bounded, although I don't think you will find this very fruitful. Instead, maybe you could try the Arzela-Ascoli theorem.
Yes, but I was in a rush, and I think it's useful to know when you're going about something the wrong way.
yes C(X,Y) is complete, so F is too. C(X,Y) isn't absolutely bounded though. Maybe you meant to say that F is absolutely bounded, which I think it is (if I understand your definition correctly - what is an e>0 net? is it just a cover by open balls of radius e?) Then compactness of F follows.
Maybe I'm missing something, but the condition on F doesn't really look like it implies total boundedness easily. It's saying that F is equicontinuous, hence my inclination to try Arzela-Ascoli.
Well looking at wikipedia statement of http://en.wikipedia.org/wiki/Arzelà-Ascoli_theorem" , it does imply that F is compact
Let X be a compact metric space, Y a metric space. Then a subset F of C(X,Y) is compact if and only if it is equicontinuous, pointwise relatively compact and closed.
In the original question, it said that F is closed and equicontinuous. Also, Y is compact => F is pointwise compact. So the original question was almost a restatement of the Arzela-Ascoli theorem anyway.
I can also see that F will be compact from Tychonoff's theorem. The space of all functions X->Y (not just continuous ones) is compact under the product topology, and F is closed with this topology.
That's an interesting observation, but is it enough here? The topology C(X,Y) gets from the compact-open subbase here is the topology of uniform convergence, i.e. the topology generated by the uniform metric, whereas the topology it gets as a subspace of the product space Y^X is the topology of pointwise convergence, which in general is strictly weaker than the former. So certainly F is going to be closed in the product topology if it's to be closed in the compact-open topology, but for the converse we need something stronger. Or did you have something else in mind?
Edit:
Evidently the equicontinuity of F can be our "something stronger", because it reduces the compact-open topology on F to the product topology. <Proof removed.> So I guess it is enough to prove that F is closed in the product topology.
eventually i realized before handing in the assignment that I should show that F is complete and totally bounded, i hope my proof is rigorous enough, well the fact that F is complete follows from the fact that Y is complete then C(X,Y) is complete then F is complete, and the condition that F satisfies assures us it's totally bounded and it's metric then it's compact.
  • · Replies 20 ·
