How Does Gauss's Law Apply to Electric Fields at Points P2 and P3?
  • Thread starter Thread starter jesuslovesu
    E-field Gauss
The discussion revolves around applying Gauss's Law to determine the electric fields at specific points (P2 and P3) related to a cylindrical charge distribution. Participants are exploring the implications of the geometry and charge distribution on the electric field calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive the electric field using Gauss's Law but questions the outcome at P2, particularly regarding the implications of being at the surface of the charged cylinder. Other participants suggest alternative methods, including using the electric field equation for point charges and integrating the electric field of a charged disk.
Participants are actively engaging with different approaches to the problem, with some questioning the applicability of Gauss's Law for finite cylinders and others suggesting methods to calculate the electric field from a charged disk. There is a mix of interpretations and attempts to clarify the setup and assumptions involved.
There are indications of confusion regarding the use of Gauss's Law for finite-length cylinders and the assumptions about charge distribution at the surface of the cylinder. Participants are also discussing the integration process for calculating the electric field, highlighting the complexity of the problem.
jesuslovesu
[SOLVED] Gauss and E-Field
http://img443.imageshack.us/img443/9452/eletroof9.th.png
My main problem with this problem is finding the electric field at Point 2 (P2)
I derived the electric field using Gauss's Law for a cylindrical charge distribution.
[tex]E (2\pi rL ) = \rho(\pi r^2 L) / \varepsilon_0[/tex]
[tex]E = \frac{\rho * r}{2\varepsilon_0}[/tex]
So I found E at P1 to be 0 V/m
Now onto finding E at P2, according to my equation, it would seem that E is 0, since the radial distance is 0, however that seems strange to me, if the point is at the surface of the charged volume cylinder, wouldn't there be some charge, I know it's not a conductor but still I would think that there would be some charge?And since I've got it all out here, is the E field at P3 just the integral [3/2L, L/2] of a charged disk?
The gausses law won't help you much here.
Try working with Ex = k*q*x/r^3.
Thanks for your reply,
I can't use Gauss's Law for finding any of the points? I know usually the cylinder is an infinite length if you want to find E, but even for Point 1 I can't use it?
Basically not in or outside finite length cylinder the tangential forces will cancel only at the midpoints. Try finding E on axis of a charged disc first.
Ok so I've got the equation for a charged disk
[tex]2\pi k \rho (1 - \frac{x}{\sqrt{x^2+a^2} ) }[/tex] how do I integrate that over the length (L) to get the electric field of the cylinder?
Would I say that dE = [tex]2\pi k \rho (1 - \frac{x}{\sqrt{x^2+a^2} ) }[/tex] and then integrate dE from 0 to L or do I need to differentiate Edisk before I do that?
Just integrate it form 0 to L, since ddQ = 2*pi*rho*a*da*dx and u integrated it along a then your equation should still contain dx.
  • · Replies 26 ·
  • · Replies 18 ·
