Area of Goalbox vs. Area of Penalty Box (rationals)
  • Thread starter Thread starter mike_302
    Area Box
The problem involves comparing the areas of the goal box and penalty box on a soccer field, represented by the expressions (10x^2) / 27 and (22x^2) / 9, respectively. The original poster seeks to determine how many times larger the penalty box is compared to the goal box.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish the areas based on dimensions and expresses confusion about calculating the size difference. Some participants suggest that the question can be approached by finding the ratio of the two areas without needing to know their exact values. Others discuss how to express the ratio in fraction form and the correct arrangement of the terms.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been provided regarding the setup of the ratio, but no consensus has been reached on the final approach.
Participants are working under the assumption that the area expressions provided by the original poster are correct, and there is a noted confusion regarding the simplicity of the problem compared to previous experiences.
mike_302
Area of goal box (soccer field) is described with (10x^2) / 27 and area of penalty box is described with (22x^2) / 9 . Determine how many times greater in size the penalty box is compared to the goal box.
I created the areas of the boxes based from dimensions, and simplified to what I have given (assume they are correct). Just don't get how to figure out that size difference (which is terrible since I just completed this question on the Fermat math contest for Waterloo earlier today, no problem, but I get thrown off in even easier math?)
read the question again. you don't even have to know the areas... it is simply asking for a ratio between the two
well ya... Simple ratio is (10x^2)/27 : (22x^2)/9 ... sooo.. would I then put that into fraction form (not sure which on top vs bottom for this situation), then simplify as far as possible...?
"Determine how many times greater in size the penalty box is compared to the goal box."
You want "penalty box" over "goal box".
(22x^2) / 9 over (10x^2) / 27 which is the same as (22x^2)/9 times 27/(10x^2).
  • · Replies 19 ·
17K
11K
