Optical absorption in Semiconductors
The discussion revolves around the optical absorption in semiconductors, specifically focusing on determining the bandgap values of semiconductor samples through experimental setups. The original poster questions the use of a chopped light source versus a constant light source in their lab report.
  • Participants explore the rationale behind using a chopped light source, discussing its advantages in measuring small changes in light levels due to absorption. Questions arise regarding the effects of the light source's brightness changes and their relation to the semiconductor's bandgap.
Some participants provide insights into how chopping the light source helps eliminate noise and improve measurement accuracy. The conversation is ongoing, with multiple interpretations of the effects of light source frequency on optical absorption being explored.
Participants note the importance of the chopper frequency in relation to potential interference, such as line noise, and the challenges posed by non-ideal light sources.
Defennder
[SOLVED] Optical absorption in Semiconductors
I'm doing a lab report on the optical absorption of semiconductors. More specifically it was to determine the bandgap values of the semiconductor samples. This is the experimental setup.
http://img518.imageshack.us/img518/5184/apparatusgt4.png
One of the questions which was asked was why a chopped light source was used instead of a constant incident light source. I can't quite figure out why.
I did some searching on the internet and found that chopping the light source allows one to convert a dc light signal into an ac (pulsed) signal, and the relevant ac signal can be extracted by using a locked-in amplifier. But I still don't understand why a dc light source can't be used instead.
You are trying to measure small changes in a light level due to absorption in the sample.
But you are also measuring changes in the brightness of the source and the response of the detector, a chopper let's you take these out.
By using a chopper you are taking the ratio of the signal with the light present and the light blocked a very short time before, any variations in the system slower than the chopper frequency are automatically removed.
You normally pick a chopper frequency at least 10-20x faster than any inteference you suspect - such as 60Hz line noise.
Is the change in brightness of the light source caused by optical absorption of the semiconductor when the frequency of the source approaches the bandgap value of the semiconductor?
the change in brightness of the detected light is caused by interactions between the light and the semiconductor.
Changes in brightness of the source you try and avoid - there will be some just because lamps aren't perfect.
I see, thanks a lot for your help.
12K
