How Can a Spring-Loaded Camming Device Be Built to Maximize Weight Support?
  • Thread starter Thread starter captnbunny
    Device
The discussion focuses on building a spring-loaded camming device for rock climbing that maximizes weight support while adhering to specific constraints: a maximum weight of 500g and dimensions under 20cm. The device will undergo static and dynamic testing within a 5cm wide, 30cm deep, and 40cm long crack. Participants emphasize the importance of researching existing camming devices and selecting appropriate materials to enhance performance and safety.
  • Understanding of mechanical engineering principles related to load-bearing structures
  • Familiarity with materials science, particularly lightweight and strong materials
  • Knowledge of rock climbing gear and camming device mechanics
  • Experience with testing methodologies for mechanical devices
  • Research existing camming devices and their design features
  • Explore materials such as aluminum alloys and carbon fiber for weight reduction
  • Learn about static and dynamic testing methods for mechanical devices
  • Investigate the physics of load distribution in rock climbing gear
Engineering students, rock climbing gear designers, and anyone involved in mechanical design and testing of load-bearing devices.
captnbunny
For my final term project I am to build a spring-loaded camming device, like those used in rock climbing, that could be fitted inside a horizontal crack and hold as much weight as possible. The device, which must weigh less than 500g and be less than 20cm long in any dimension, will be tested in two ways:
Static test, in which weights are gradually added to the device
Dynamic test, in which weights are attached to the device, raised, and then dropped
The crack itself is 5cm wide, 30 cm deep and 40cm long, and the device must only contact the inside walls of the crack.
This project is due in about three weeks and no one in my class seems to have any idea how to do this. Could someone please tell me where to begin?
Thanks in advance. :smile:
well, you're designing something that already exists, so why not start with researching existing camming devices?
What materials should I use?
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 54 ·
