How Much Force is Needed to Move a Block on a Wall?
The discussion centers on calculating the forces required to move a block weighing 64.4 N against a vertical wall with a static friction coefficient of 0.580. The minimum force needed to prevent the block from sliding down the wall is determined to be 37.52 N. Additionally, the same force of 37.52 N is required to initiate upward movement of the block, as the direction of the static frictional force changes in both scenarios.
  • Understanding of static friction and its coefficient
  • Basic principles of force and motion
  • Knowledge of Newton's laws of motion
  • Ability to perform calculations involving forces
  • Study the concept of static friction in detail
  • Learn about Newton's laws of motion and their applications
  • Explore the calculations involved in force diagrams
  • Investigate real-world applications of friction in engineering
Students in physics, engineers working with mechanical systems, and anyone interested in understanding the principles of force and friction in practical applications.
james2mart
The weight of the block in the drawing (SEE ATTACHMENT) is 64.4 N. The coefficient of static friction between the block and the vertical wall is 0.580.
(a) What minimum force is required to prevent the block from sliding down the wall? (Hint: The static frictional force exerted on the block is directed upward, parallel to the wall.)
(b) What minimum force is required to start the block moving up the wall? (Hint: The static frictional force is now directed down the wall.)
I can't figure this out...
a) The minimum force required to prevent the block from sliding down the wall is 37.52 N. b) The minimum force required to start the block moving up the wall is 37.52 N.
