How Do Newton's Laws Apply to a Lemon Half on a Frictionless Surface?
The discussion revolves around applying Newton's laws to a lemon half on a frictionless surface, focusing on the forces acting on it under different conditions of motion: zero velocity, constant velocity, and varying velocity. Participants are analyzing the forces involved and their components in relation to the mass of the lemon half.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants have attempted to resolve the problem by breaking down the forces into their x and y components and applying Newton's second law. Questions arise regarding the differences in approach for zero, constant, and varying velocities, as well as how to correctly derive the necessary third force.
There is ongoing exploration of the problem with various attempts to calculate the third force under different conditions. Some participants express uncertainty about their calculations and seek clarification on the relationship between velocity and the forces acting on the lemon half. Guidance has been offered regarding the need to show work before receiving assistance.
Participants are working under the constraints of a homework assignment, which may limit the information they can provide or the methods they can use. There is a noted confusion regarding the application of forces in relation to different states of motion.
iamkristing
1. A figure shows an overhead view of a lemon half and two of the three horizontal forces that act on it as it is on a frictionless table. Force F1 has a magnitude of 4.70 N (in the negative x and positive y direction) and is at θ 1 = 29°. Force F2 has a magnitude of 7.00 N (in the positive x and negative y direction) and is at θ 2 = 29°. The lemon half has mass 0.0200 kg.
(a) What is the third force if the lemon half has zero velocity?
(b) What is the third force if the lemon half has constant velocity? v = (13.0 - 14.0 ) m/s
(c) What is the third force if the lemon half has a varying velocity? v = (13.0t - 14.0t ) m/s, where t is time in seconds
2. F= m*a
3. I divided the two forces into x and y components. I then added them together and found the x and y component needed for the lemon not to move. I'm not sure how to use these components to find velocity though.
Also, is there a difference between constant and varying velocity for this problem?
You need to show some working or an attempt before someone helps you.
sorry I have attempted.
I found the x and y components of the first force to be x= -4.11 and y=2.28 and the second force to be y= -3.39 and x=6.12
for the lemon not to move, I found that the third force's x and y components were equal to x=-2.11 and y=1.11
now I did the same except when solving for the third force i set each component equal to the constant velocity. I got x=10.99 and y=-12.89
for the varying velocity question, I know the derivative of velocity is acceleration. So i found the derivative of that function and then applied F=ma. I got x=0.26 abd y=-0.28
Now none of these answers are right and I can't see where I'm going wrong...
I just tried the problem again, taking into account the velocity and acceleration. I thought I missed that before.
So I used the sum of the forces = mass*acceleration
I thought, with zero velocity, no other force would be needed because the velocity doesn't change.
Also, for constant velocity, I found the third force vector needed. I found that to be x=-2.01 and y=1.12
Now for varying velocity, I took the derivative of the velocity the problem gave me. I found the acceleration to be 13 in the x direction and 14 in the y direction. I used F=ma and plugged in the mass of the lemon and the acceleration and got:
F in x direction = 2.27
F in y direction = -0.84
Still though, I cannot come up with the answer. Any help or point in the right direction will be helpful!
