How Does Changing Arm Position Affect Angular Velocity and Work Done?
The discussion focuses on the physics of angular momentum and work done when a man changes his arm position while standing on a frictionless rotating plate. In case A, with arms extended, the initial angular velocity is denoted as omega_0, and the moment of inertia is I_0. When the arms are lowered in case B, the new angular velocity is calculated as omega_1 = 2 omega_0, with the moment of inertia reduced to I_0 / 2. The work done to achieve this configuration is expressed as U = 0.5 * I_0 * (omega_0)^2 - 2mgl.
  • Understanding of angular momentum and conservation laws
  • Familiarity with moment of inertia calculations
  • Knowledge of rotational dynamics and angular velocity
  • Basic grasp of work-energy principles in physics
  • Study the conservation of angular momentum in rotating systems
  • Learn about the relationship between moment of inertia and angular velocity
  • Explore work-energy theorem applications in rotational motion
  • Investigate the effects of changing mass distribution on angular velocity
Students of physics, particularly those studying rotational dynamics, as well as educators and anyone interested in understanding the principles of angular momentum and work in mechanical systems.
PeterPoPS
A man is standing on a rotating plate (rotates without friction). In case A he is hold 1weight in each hand (straight out) with the mass m and he is rotatin with angular velocity omega_0.
Then he moves his arms down so they are parallell to the body (case B) and increases his angular velocity to omega_1.
Calculate the new angular velocity omega_1 and the work U which the man must do to change his body configuration to case B.
You can assume that the moment of inertia on z-axis for the man is I_0 in case A and I_0 / 2 in case B.
The length of the arms of the man is l, so each weight are l units out in case A and lowered l units (and ofcourse moved l units toward the body) in case B.
the answers are given
omega_1 = 2 omega_0
and
U = 0.5*I_0*(omega_0)^2 - 2mgl
My Problem is i get how to calculate the angular velocity omega_1
But I don't understand how to even start on calculating the work done.
Best regards /Peter
For omega_1 I used the formulaI = I_0 + 2ml^2so I_1 / I_0 = omega_1 / omega_0and then got that omega_1 = 2 omega_0
18K
  • · Replies 22 ·
