Improper Integrals: Evaluate & Determine Convergence
  • Thread starter Thread starter physstudent1
    Integrals
The discussion revolves around determining the convergence of the improper integral of the function \( \frac{1}{x \ln x} \) from 1 to 2. Participants explore the implications of the integrand's behavior near the lower limit of integration, particularly the logarithmic term.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the evaluation of the integral and the implications of limits approaching problematic values, such as \( \ln(0) \). There are inquiries about the selection of comparison functions for convergence tests and the proper handling of limits in definite integrals.
Several participants have offered insights into the evaluation process, including the use of limits and substitution methods. There is an ongoing exploration of the implications of these approaches, with some participants expressing uncertainty about the limits and convergence conclusions.
Some participants note confusion regarding the limits of integration after substitution and the notation used for small values approaching zero. The discussion reflects a range of interpretations and attempts to clarify the steps involved in evaluating the integral.
physstudent1
Determine whether the improper integral converges and, if so, evaluate it.
the limits of integration are 1 to 2
the integrand is
(dx/(xlnx))
so first I found the indefinite integral which was ln(ln(x)) + c
now usually these problems have infinite for one of the limits of integration in which case that limit becomes a variable such as a or b, with this one I did notice that the the ln(ln(1)) is going to be taking the ln(0) which you cannot do I'm not sure what to do from here though or what limit I am supposed to be evaluating to see if it converges or not.
Have you dealt with things like:
[tex]\int_{0}^{1} \frac{1}{x^2} dx[/tex]
oh if the exponent is >= 1 then the integral is infinite right?
so if f(x)>=g(x)>=0
if the integral of a to infinite of f(x) converges then the integral of a to infinite of g(x) conveges and
if the integral of a to infinite of g(x) diverges then the integral of a to infinite of f(x) diverges
how would I go about selecting a function that is less then the one I was given though.
You should be able to work it out with:
[tex]\lim_{a \rightarrow 1^+} \int_a^2 \frac{1}{x \ln x} dx[/tex]
ok I figured that limit is positive infinite correct? which would mean it diverges ?
I get that it diverges also.
what is the integral of 1/xlnx dx
[tex]\ln(\ln x)+C[/tex]
(Just like you have.)
integ dx/xlnx, take the sub lnx=t, dx/x=dt, from here we get
integ dt/t=lnt
but since he is taking a definite integral he need not go back to the original variable, so that means
lim (e-->0) integ(from 1+e to 2) of dx/xlnx=lim(e-->0) ln(t) on the interval 1+e to 2, hence
lim(e-->0) [ln2-ln(1+e)]=ln2
so it converges!
sutupidmath said:
so it converges!
I see what you did with the substitution, but you got the limits wrong.
[tex]\int^2_1\frac{1}{xlnx}dx[/tex] [tex]u=lnx => du = \frac{dx}_{x}[/tex]
Now you have to plug in you original limits to find out what the limits in u are.
[tex]ln(1) = 0 , ln(2) = ln(2)[/tex]
in the end you end up with;
[tex]ln(ln2) - ln(0)[/tex]
[tex]ln(x) -> -\infty as x -> 0[/tex]
So it diverges.
where are you getting e from?
So it diverges.
Oh yeah, sorry my bad. I totally missed this part. I can't believe i forgot to change the limits of integration after i made that substitution!
I just let e =epsylon, sorry i should have defined that!
  • · Replies 16 ·
  • · Replies 54 ·
19K
