How High Must a Parabolic Arch Be for Minimum Clearance Over a Stream?
  • Thread starter Thread starter ahmadmz
The problem involves determining the height of a parabolic arch that spans a stream, requiring a minimum clearance over a central channel. The arch must accommodate specific width and height constraints, with a focus on the mathematical representation of the parabola.
  • Mixed
  • Participants discuss the placement of the parabola and the values needed to define its equation. There are attempts to derive relationships between parameters such as 'a' and 'n', and some participants suggest reasoning through the problem without extensive calculations.
Multiple approaches to the problem have been shared, with some participants expressing confidence in their methods while others question the results. There is an ongoing exploration of different interpretations and calculations, with no clear consensus on the final outcome.
Participants mention the context of the problem, speculating on its source from algebra courses and expressing interest in similar problems involving parabolas and conic sections. There is also acknowledgment of the challenges faced in self-studying these concepts.
ahmadmz
A parabolic arch spans a stream 200 feet wide. How high
must the arch be above the stream to give a minimum
clearance of 40 feet over a channel in the center that is
120 feet wide?
They are asking for the k value right?
If I place the parabola starting from x=0,y=0 then the vertex is at (100,40+n).
When x=40,y=40. x=160,y=40 I want to find out what y is when x=100.
So I used the equation (x-h)^2 = a(y-k)
(x-100)^2 = a(y-(40+n)) After using x=40 ,y=40 I get n=-3600/a And now I have no idea what to do .. Am I doing this right?
I think so. Why not just put x=0 and y=0 into your equation and get another relation between 'a' and 'n'?
I think you can just reason it out, no need for all those crazy equations and what have you
Basically you're going to have a parabola that crosses the x-axis at x=-100 and x=100
You need at least y=40 at x=60 and -60, that ultimately what it's asking, right? And it's basically of the form Y=-Ax^2+H (I just centered it at 0 for ease)
H is what we're looking for, and A is also unknown, however we know if y=40, then x=60, and if y=0, x=100
I went ahead and finished this out to find A and H and checked it and it was right, see if you can follow.
Ok I used the equation y=-ax^2+h with the values x=60,y=40 and x=100,y=0.
Then solved the system and got a = -1/160 and h = 62.5 (the answer for the question).
And the equation of the parabola is y=-1/160x^2+62.5
Thanks for the help :). This is the first time I've done a question like this and I had trouble approaching it. I'm self studying these days and this shows i got a long way to go.
I feel your pain, I been self-studying for months now. I'm proud of you :-] Keep at it!
I performed a process somewhat like what was described in #3 and #4, but obtained a somewhat different result. The standard form of a parabola was still necessary.
Do you know of any other interesting problems like this; using parabolas or other conic sections? Interesting and varied problems are often difficult to find. Also, I'm curious; was the question in post #1 from PreCalculus, or was it from Intermediate Algebra (I suspect it is from PreCalculus). Once in a while, I restudy College Algebra or Intermediate Algebra, and the applied situation exercises are often interesting but I just do not find enough of them.
What result did you get symbolipoint? The book says the answer is 62.5 which i got.
I am studying conics right now and I'll let you know if I find any more similar problems. This is from a intermediate algebra book. You are correct that most books do not have many problems like these. They are indeed interesting :)
I just wrote a lengthy response and the forum cut me off.
In short, [tex]\[<br /> f(x) = - \frac{1}{{90}}x^2 + 40 + 71{\textstyle{1 \over 9}}<br /> \][/tex]
I used an "untranslated" parabola, and then a "translated" parabola. Too difficult to rewrite all the details NOW. One used x=60, the other relied on x=100.
Hmm I think you made a mistake somewhere. Can someone confirm the answer please? What did you get blochwave?
Blockwave understood the problem description. I may have obtained the "wrong" answer because I did not fully understand the problem description. Yet, he seems to have taken most of the approach that I took. Are we both misunderstanding something?
  • · Replies 17 ·
11K
13K
9K
