Potential Energy on an ideal spring
The problem involves calculating the total length of an ideal spring when a specific amount of potential energy is stored in it. The context includes the application of Hooke's law and the relationship between potential energy and spring displacement.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of the spring constant based on the initial stretch caused by a weight. There are various attempts to apply the potential energy formula for springs and questions about the correct interpretation of gravitational versus elastic potential energy.
Multiple interpretations of the problem are being explored, with some participants suggesting different equations and approaches. Guidance has been offered regarding the calculation of the spring constant and the implications of the potential energy formula, but no consensus on a final method has been reached.
Participants note that the problem may have two possible answers for the total length of the spring, and there is some confusion regarding the units of the spring constant and the types of potential energy involved.
clope023
[SOLVED] Potential Energy on an ideal spring
An ideal spring of negligible mass is 12.00cm long when nothing is attached to it. When you hang a 3.15kg weight from it, you measure its length to be 13.30cm.
If you wanted to store 10.0J of potential energy in this spring, what would be its total length? Assume that it continues to obey Hooke's law. (also says there might be 2 answers)
K1 + U1 + Wother
= K2 + U2
or
Wel = 1/2ky1^2 - 1/2ky2^2
= Uel1 - Uel2
U = mgy
12cm = .12m = y1
13.30cm = .133m = y2
10J = Wother
1/2ky1^2 = 10J + mgy1 + 1/2ky2^2
1/2k(.0144m^2) = 10J + (3.15kg)(9.8m/s^2)(.133m) + 1/2k(.0177m^2)
-14.11J = 1/2k(.0177m^2-.0144m^2)
-14.11J = 1/2k(.0033m^2)
-28.22J = k(.0033m^2)
-28.22m = (.003m^2)
is this right? would I just divide -28.22m by .003m^2 and get a #? I'm pretty sure it's not right but I'm not sure of other equations to use, should I use kinematics as well?
edit: or perhaps I should have another potential energy in there for y1? or use the potential energy for mass in y1 and solve for y2?
or perhaps use this equation?
K1 + Ugrav1 + Uel1 + Wother = K2 + Ugrav2 + Uel2
seems like this would work better than what I was using?
The potential energy of a spring is given by:
[tex]U=\frac{1}{2}kx^2[/tex]
You can work out the spring constant from the initial info they give you.
you saying I should do:
10J = 1/2k((.133m)^2-(.12m)^2))
20J = k(.0033m^2)
20J/.003m^2 = k
k = 6060?
or should I use the gravitational potentiona energy from the 3.15kg mass?
(3.15)gy = 1/2k((.133m)^2-(.12m)^2))?
You need to work out the spring constant by how far the mass stretches the spring, then use the potential energy formula I gave to solve for x. Since the answer will involve a square root there will be two answers.
so:
10J = 1/2k(.133m)^2
20J = k(.0177m^2)
20J/.0177m^2 = k
1129.9 = k
and mgy = 1/2kx^2
(3.15(9.8)(.133m)2/k)^1/2 = x?
x = -8.5cm, 8.5cm ?
The spring constant is a force per unit length. You can work it out by dividing the weight of the mass by how much the spring moves from equilibrium. Then solve for x in the potential energy equation.
so k = (mg)/y2 = (13.5*9.8)/.133m = 232J?
and is the potential energy in the equation you gave gravitational or elastic?
cause I could solve it like this
mgy = 1/2kx^2
4.11J = 1/2kx^2
8.22J = kx^2
8.22J/232J = x^2
.035 = x^2
x = -.188m, .188m = -19cm, 19cm?\
or is it:
10J = 1/2kx^2
20J = kx^2
20J/232J = x^2
.086 = x^2
x = -.29m, .29m = -29cm, 29cm?
No, the spring stretches 1.3cm from equilibrium. The units of the spring constant are not joules. The only purpose of the information about the mass is so you can determine the spring constant.
Its the elastic potential energy. That is the energy stored in the spring.
Now you know how to obtain the spring constant and you know how much energy you want to store you can solve for x in the potential energy equation.
ooooooooh, it goes from 12cm to 13.3cm which is 1.3cm which .013m, so
Fx = kx, k = Fx/x = = (3.15kg*9.8m/s^2)/.013m = 30.9N/.013m = 2377N/m
and 10J = 1/2kx^2
20J = kx^2
20J/(2377N/m) = x^2
x = .092m = -9.2cm, 9.2cm?
Thats good but they want the total length. So that will be 12cm +/- 9.2.
right the initial length when nothing was attached to it, so it would be:
2.8, 21.2? thanks a lot!
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 17 ·
