Electric field formula vs coulombs law, contradiction?
The discussion centers on the apparent contradiction between the electric field formula and Coulomb's law when applied to parallel plate capacitors. The electric field (E) between two charged plates is defined as E=U/d, where U is voltage and d is the distance between the plates. This leads to the conclusion that the force on a charged particle remains constant regardless of its position between the plates. However, when applying Coulomb's law to treat the plates as point charges, different results emerge, particularly when considering large distances. The resolution lies in the fact that the formulas for electric fields in parallel plate capacitors are valid only when the dimensions of the plates are significantly larger than the distance between them.
  • Understanding of electric fields and forces
  • Familiarity with Coulomb's law
  • Knowledge of parallel plate capacitors
  • Basic grasp of voltage and capacitance concepts
  • Study the derivation of the electric field between parallel plates
  • Explore the limitations of Coulomb's law in different geometries
  • Learn about the concept of electric field lines and their implications
  • Investigate the effects of distance on electric field strength in various configurations
High school students, physics enthusiasts, and anyone interested in understanding the principles of electric fields and capacitors.
Kurret
1) between two charged plates, the electric field is given by E=U/d=F/Q->F=QE
that means that the force on a particle between these two plates is independent on the position between them. But consider that you have two plates separated by a huge distance, then the force is constant wherever we place a charged particle between the plates. But if we use coulombs law and treat the plates as other charged particles we will get different results. How come?
2) in a plate? condensator we have C=eA/d (e=permitivity constant, d=distance, A=the plates area)
we also have C=Q/U
putting these equal to each other gives:
eA/d=Q/U -> Q/(eA)=U/d=E
ie the electrical field, and the force on a prarticle in between the plates, is independent on the distance between the plates. I can't really get the logic in this one. for example let's say we have two charged plates with a distance of 1 cm from each other, and then we move one plate away to the andromeda galaxy. That the force on a particle wherever in between these two plates still should be the same as with the distance of 1 cm is just absurd.
Can someone explain these results? I am only still in high school so I haven't studied so much advanced physics. Is it maybe because the formula for the electric field is just an apporximation of the real world?
These are reasonable questions. All of these parallel plate capacitor equations only work when the dimension of the plates is much greater than the spacing between the plates. With these constraints, the cases you describe follow as the formulas say they should.
  • · Replies 17 ·
  • · Replies 44 ·
