Gravimetric analysis of a carbonate
  • Thread starter Thread starter g07l0989
    Analysis
In a gravimetric analysis of a carbonate, a 0.100g sample was titrated with excess acid, resulting in CO2 collection in Ba(OH)3 solution. The discussion involves calculating the percentage of carbonate in the sample using the moles of HCl and Ba(OH)2. The key point is that CO2 exists in a 1:1 ratio with carbonate, leading to confusion about whether to report the amount of carbonate as CO3^2- or as M^2+CO3^2-. Further information is needed to determine the correct approach for calculating the mass of carbonate in the sample. The analysis hinges on understanding the stoichiometric relationships in the reactions involved.
g07l0989
question
during a gravimetric anaalysis of a carbonate sample ,0.100g sample was titrated with excess acid the resultant carbon dioxide was collected in 40.0cm3 of 0.05 mol/dm3
Ba(OH)3 solution:
MCO3 + 2H=M+CO2
CO2+ Ba(OH)2=BaCO3 +H2O
Ba(OH)2 uses 22 cm3 of a 0.091 mol/dm3 HCl calculate the % of the carbonate is sample??"
well i found the number of moles of the HCl which i compared to the number of moles of BA(OH)2 by ratio the i got the number of moles of the Ba(OH)2 that was initially ther ,i then substrated that answer to from that that was titrated therefore getting the number of moles of caorbin dioxide but i don't know whether i relate the number of moles of CO2 to the M(see equation)or to MCO3.and wat i do after that to get the mass of the carbonate in the sample...please help if you can!thanks
You have analyzed for CO2 which exists in a 1:1 ratio to carbonate (CO_3^{-2}). Will you report the amount of carbonate as CO_3^{-2} or as M^{+2}CO_3^{-2}. The former is straightforward but you haven't given enough information here to answer the latter.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
