| Thread Closed |
What's wrong? Electron acceleration |
Share Thread |
| Feb23-08, 11:26 AM | #1 |
I am working on this problem but I got it wrong. I'm not sure what happened.
1. The problem statement, all variables and given/known data An electron with initial velocity Vo = 2.3e5 m/s enters a region 1.0 cm long where it is electrically accelerated. It emerges with velocity v = 4.10e6 m/s. What was its acceleration, assumed constant? _________ m/s^2 2. Relevant equations DeltaX = 1/2 (Vo + V)t V = Vo +at 3. The attempt at a solution I thought these were my known variables: Vo = 2.3e5 m/s DeltaX = 1.0 cm Vf = 4.10e6 m/s I tried to solve for t using DeltX equation. I got 4e-9 s. Then I tried to solve for a using my new value for t and V equation. I got 9.675e14 m/s^2 which is wrong. So anyone know what happened? 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Feb23-08, 11:40 AM | #2 |
Vr+V0= 4100000+ 230000= 433000 or 4.33 e5 m/s. Half of that is 2.665 e5 and deltax= 1 cm= 0.01 m. t= 0.01/(2.665 e5= 3.75 e-8 s, not -9. Try your calculation again, not using scientific notation this time. That may be what is confusing you.
Vf- V0= 4100000- 230000= 387000 or 3.87 e5 m/s. Dividing that by 3.75 e-8 gives an acceleration of 1 x 1014 m/s2. Your equations are right. Check your arithmetic. |
| Feb23-08, 12:21 PM | #3 |
Thank you. When I solved for t, i got .000000004 and I thought it would be like totally okay to just use 4e-9. When I tried it again I got a more specific number by using SN button on my calculator. Using 4.6189e-9 for t, I got the right answer. 8.37855e14
| Thread Closed |
Similar discussions for: What's wrong? Electron acceleration
| Acceleration of electron?? | Introductory Physics Homework | 2 | ||
| Electron Acceleration | Introductory Physics Homework | 4 | ||
| why my answer is wrong? --- remove electron from orbital | Biology, Chemistry & Other Homework | 6 | ||
| electron acceleration Qs? | Introductory Physics Homework | 9 | ||
| acceleration of an electron | Introductory Physics Homework | 4 | ||
