Help with Coulomb's Law: Solving for Charges on Identical Spheres
  • Thread starter Thread starter Saladsamurai
    Coulomb's law Law
The discussion revolves around a problem involving Coulomb's Law, specifically regarding the electrostatic forces between two identical conducting spheres with initial charges. The original poster is attempting to determine the charges on the spheres based on given forces before and after they are connected by a wire.
  • Mixed
  • The original poster presents two attempts to solve a system of equations derived from Coulomb's Law and conservation of charge, noting discrepancies in their results.
  • Some participants question the correctness of the equations used, particularly regarding the signs and magnitudes of the charges.
  • There is a focus on the interpretation of the equations and the implications of the signs in the context of the problem.
Participants are actively engaging with the original poster's attempts, providing feedback on the equations and suggesting potential errors. There is a recognition of differing interpretations of the equations, and some guidance is offered regarding the signs of the charges involved.
Participants highlight the importance of considering the signs of the charges in Coulomb's Law, as one charge is negative and the other is positive. There is also mention of potential errors in the original equations presented by the poster.
Saladsamurai
!Coulomb's Law!
So I have already solved this one before, but I was redoing it fir practice when I encountered something that is troubling me. Depending on how I choose to solve my two equations, I get different results. Surely I am doing something wrong, but I cannot see it.
Problem
Two identical conducting spheres, fixed in place, attract each other with an electrostatic force of .108 N when their center-to-center separation is 50 cm. The spheres are then connected by a thin conducting wire. When the wire is disconnected, the spheres repel each other with an electrostatic force of .036 N. Of the initial charges on the spheres, with a positive net charge, what was the (a) negative charge of one of them and (b) the positive charge of the other?
Now I have used conservation of charge for after they connect and I end up with two equations and two unknowns:
[tex]F_e=\frac{kq_1q_2}{r^2}\Rightarrow q_1q_2=3.00(10^{-12})[/tex] (1)
[tex]F_e'=k\frac{(\frac{q_1+q_2}{2})^2}{r^2}\Rightarrow q_1+q_2=2.00(10^{-6})[/tex] (2)
Attempt 1:
If I solve (2) for q_1 then [itex]q_1=2(10^{-6})-q_2[/itex]
plugging the above into (1) [itex]-q_2^2+2(10^{-6})q_2-3(10^{-12})=0[/itex] gets me a nonreal answer.
Attempt 2:
BUT if I solve (1) for q_1 then [itex]q_1=\frac{3(10^{-12})}{q_2}[/itex] and plugging that into (2) I get [itex]q_2^2-2(10^{-6})q_2-3(10^{-12})=0[/itex] which solves correctly.
I am consistently of by a sign in the first attempt. Can anyone see what the problem is?
Saladsamurai said:
Attempt 2:
Wouldn't that be + (plus) 3e-12? (Resulting in an equivalent expression to than in attempt 1.)
No. Attempt 2 is correct. Attempt 1 is not.
Awaking this thread. I just went back to try this again and have the same problem... so conceptually, something is off.
Hi Saladsamurai,
In your original post you have an error in equation 1. There is then another mathematical error in method 2 that counteracts the error in equation 1 and gives the right answer.
For your equation 1, you have:
but that is not right. The formula for Coulomb's law is normally given in terms of magnitudes:
[tex]F_e=\frac{k |q_1||q_2|}{r^2}[/tex]
and so you get:
[tex] |q_1 q_2|=3 \times 10^{-12}[/tex]
You know that either q1 or q2 is negative, and the other is positive, so your equation 1 should be:
[tex] q_1 q_2 = - 3 \times 10^{-12}[/tex]
In your method 2, the quadratic equation you get is the correct equation to get; however, it is not what you get from your original equations 1 and 2 in your post. If you use your original equations, the [itex]3\times 10^{-12}[/itex] term turns out to be positive, which gives the same (nonreal) answer as method 1.
  • · Replies 30 ·
