Expanding a function in Gaussian-Hermites
  • Thread starter Thread starter alfredska
    Expanding Function
The discussion revolves around expanding a function, specifically a Gaussian, in terms of Gaussian-Hermite polynomials. The original poster seeks to understand the correct formulation of coefficients in this expansion and the implications of including a weight function.
  • Participants discuss the normalization of Hermite polynomials and the correct formulation of coefficients for the expansion. There are questions about the orthogonality of the functions involved and the potential need for a weight function to resolve issues with non-orthogonality.
Participants are actively exploring different approaches to the problem, including the introduction of a weight function to achieve orthogonality. Some have proposed methods for integrating the Gaussian with Hermite polynomials, while others are still considering the implications of changing the function being expanded.
There is mention of a potential calculation error and the need for clarification on whether the function being expanded is a sine function or a Gaussian. The discussion reflects a mix of correct and incorrect assumptions about the properties of the functions involved.
alfredska
Expanding a function in "Gaussian-Hermites"
This isn't homework or coursework, but seeing as it's most like a homework problem, I figured this would be the best place to ask.
Note that I'm using the physics
I would like to expand a function (let's take a gaussian for example) in terms of this series (very similar to the harmonic oscillator, except for a factor of 2 in the exponential):
[tex]s\left(x\right)=\sum_n\alpha_nH_n\left(x\right)\exp\left(-x^2\right)[/tex]
To find the coefficients:
[tex]\alpha_n=\int_{-\infty}^{\infty}F\left(x\right)H_n\left(x\right)\exp\left(-x^2\right)dx/Normalization[/tex]
where [tex]F\left(x\right)=\exp\left(-\frac{x^2}{\sigma^2}\right)[/tex] in my example
I have figured out the normalization of [tex]H_n\left(x\right)\exp\left(-x^2\right)[/tex]
[tex]\alpha_n=\int_{-\infty}^{\infty}\left[H_n\left(x\right)\exp\left(-x^2\right)\right]^2dx=\sqrt{\frac{\pi}{2}}\left(2 n-1\right)![/tex]
but apparently I'm doing something wrong when I write:
[tex]\alpha_n=\frac{\int_{-\infty}^{\infty}\exp\left(-\frac{x^2}{\sigma^2}\right)H_n\left(x\right)\exp\left(-x^2\right)dx}{\sqrt{\sqrt{\frac{\pi}{2}}\left(2 n-1\right)!}}[/tex]
Can you tell me where I'm making my mistake?
I looked for the Hermite series expansion in one of my books and this is what I came up with:
The function f(x) can be expanded as:
[tex]f(x)=\sum_{n=0}^{\infty}A_n\cdot H_n(x)[/tex]
With:
[tex]A_n=\frac{1}{2^n n! \sqrt{\pi}} \int_{-\infty}^{+\infty} e^{-x^2}f(x) H_n(x)dx[/tex]
And:
[tex]H_n(x)=(-1)^n e^{x^2}\frac{d^n}{dx^n}\left(e^{-x^2}\right)[/tex]
It's getting late over here, I will try to check it tomorrow. I think you made a calculation error somewhere. However because the function f(x)=sin(x) is not a polynome, you have to calculate the general integral for n, otherwise it would have been a lot easier. We'll see after a nights sleep.
The [tex]A_n[/tex] you've listed is correct for expanding a function in a series of Hermites alone. Since I have a Gaussian tacked on my Hermites, my case is slightly different.
One place I've found out that I'm going wrong, is that the functions which I'm summing are not mutually orthonormal, they're not even orthogonal. Can this be resolved by including a weight function?
I'm guessing [tex]w(x) = e^{x^2}[/tex] might work? Since it seems to reduce it to the orthogonality condition of the regular Hermite polynomials
You're right in that it reduces it down to the orthogonality case, but then s(x) would need the weight function thrown in as well, and I'm back to the harmonic oscillator.
alfredska, I didn't have time yet to look into it. I will try to do it this week, however I'm not giving any guarantee for a solution. Anyway, I'll come back to it.
Perhaps Solved
Ok, I believe I've figured out how to approach this problem. This is likely just another way of implementing weights, and siddharth was probably correct, but I still had to feel my way through it.
My approach:
Take
[tex]\exp\left(-\frac{x^2}{2}\right)[/tex]
out of the summation and meld it into [tex]s\left(x\right)[/tex], defining a new function
[tex]g\left(x\right)=s\left(x\right)\exp\left(\frac{x^2}{2}\right)[/tex].
Now the summation is clearly identifiable as the harmonic oscillator, and
[tex]\alpha_n=\frac{\int_{-\infty}^{\infty}g\left(x\right)H_n\left(x\right)\exp\left(-\frac{x^2}{2}\right)dx}{\sqrt{2^nn!\sqrt{\pi}}}[/tex]
After I find my coefficients, I only have to revert g(x) back to s(x)
This seems to be the right way to solve it. I will try to evaluate the integral for determining the coefficients. However what is the exact function, a sin or a Gauss function? There seems to be something changed if I'm not mistaken.
I did change the function
You're right coomast, I did change the function which is being expanded. The method should apply to either case though. For the sake of anyone who may stumble upon this thread, here are the results:
[tex]s\left(x\right)=\sum_n \alpha_n \frac{H_n\left(x\right)}{\sqrt{2^nn!\sqrt{\pi}}} \exp\left(-x^2\right)[/tex]
[tex]\frac{s\left(x\right)}{\exp\left(-\frac{x^2}{2}\right)}=\sum_n \alpha_n \frac{H_n\left(x\right)}{\sqrt{2^nn!\sqrt{\pi}}} \exp\left(-\frac{x^2}{2}\right)[/tex]
[tex]\alpha_n=\int_{-\infty}^{\infty} \frac{H_n\left(x\right)}{\sqrt{2^nn!\sqrt{\pi}}} \exp\left(-\frac{x^2}{2}\right) \frac{s\left(x\right)}{\exp\left(-\frac{x^2}{2}\right)} dx[/tex]
[tex]\alpha_n=\int_{-\infty}^{\infty} \frac{H_n\left(x\right)}{\sqrt{2^nn!\sqrt{\pi}}} s\left(x\right) dx[/tex]
Thanks for you interest.
~Matt
  • · Replies 47 ·
  • · Replies 105 ·
13K
