Magnetic plus gravitation force
The discussion centers on calculating the magnitude of the magnetic field in a circuit involving springs and a mass under the influence of gravity and magnetism. The circuit features a 24V battery and a 12-ohm resistance, with a 10-gram mass causing the springs to stretch. The user initially misapplied the gravitational constant instead of the acceleration due to gravity (9.8 m/s²), leading to a significant error in their calculations. The correct magnetic field strength is determined to be 0.588 Tesla after correcting the gravitational force used in the calculations.
  • Understanding of Hooke's Law (F = -kx)
  • Basic knowledge of electric circuits (Ohm's Law: I = V/R)
  • Familiarity with magnetic force equations (F sub B = IL x B)
  • Knowledge of gravitational force (F = mg)
  • Review the application of Hooke's Law in mechanical systems
  • Study the principles of electromagnetism, focusing on magnetic fields and forces
  • Learn about the differences between gravitational constants and acceleration due to gravity
  • Explore circuit analysis techniques involving resistors and power sources
Physics students, electrical engineers, and anyone interested in understanding the interaction between magnetic and gravitational forces in mechanical systems.
eagleswings
[SOLVED] magnetic plus gravitation force
A circuit consists of wires at the top and bottom and identical metal springs in the left and right sides. the upper portion of the circuit is fixed and has a 24 v battery and 12 ohm resistance. the wire at the bottom has a mass of 10 grams and is 5 cm long. the springs stretch 0.5 cm under the weight of the wire. when a magnetic field is turned on, directed out of the page, the springs stretch an additional .3 cm. what is the magnitude of the magnetic field.
F = -kx, I = v/r = 2 Amps, F = ma = mg; F sub B = IL x B
solving for K before the magnetic field is turned on: there are two upward forces from the springs, and one downward force from gravity and mass
-2kx = - mg
substitute -2 (-.005 m)(k) = (-.01kg)(6.673 x 10 -11)
k = 6.673 x 10 -12
springs are in equilibrium between 2 kx forces and mg force
now magnetic field is turned on and you have 2 -kx's and F sub B, where springs stretch another 0.3 cm or .003 meters
-2 (6.673 x 10 -12)(.003) = F sub b = IL x B = (2 A) (5 cm) x B
so B = (4.00 x 10 - 14)/(2)(.05) = 4.0 x 10 - 13 tesla
but the book answer is .588 Tesla - i am only off by a factor of a trillion or so
this should be easy but i am missing a big factor
magnetic plus gravitation force Picture
i've attached a picture of the problem. i can't figure out how i could be so far off? what element of the problem am i missing?
Magnetic plus gravitation solved
well i was using the Big G gravitational constant instead of little g acceleration = 9.8 meters/sec
  • · Replies 22 ·
  • · Replies 31 ·
