Differential Cross Section for scattering by Hard Sphere
The discussion revolves around determining the differential and total cross sections for scattering from a hard sphere of radius R. The original poster presents relevant formulae and expresses uncertainty about deriving an equation relating the impact parameter and scattering angle, particularly in the context of a hard sphere potential.
  • Participants explore the relationship between impact parameters and scattering angles, with some suggesting geometric approaches. Others question the applicability of quantum mechanical methods like the Born approximation to this classical problem.
There is an ongoing exploration of different methods to approach the problem, with some participants providing links to resources and discussing the relevance of classical versus quantum treatments. The original poster has indicated some progress in understanding the problem.
Participants note the potential confusion regarding whether the problem should be approached from a classical or quantum perspective, as well as the limitations of certain methods for hard sphere scattering.
logic smogic
Problem
Determine the differential and total cross sections for scattering from a "hard
sphere" of radius R ("hard" means impenetrable).
Relevant Formulae
[tex]\sigma (\Omega) d \Omega = \frac{number \ of \ particles \ scattered \ into \ solid \ angle \ per \ unit \ time}{incident \ intensity}[/tex], cross section of scattering
[tex]d \Omega = 2 \pi sin \Theta d \Theta[/tex], solid angle, with [tex]\Theta[/tex] as the scattering angle
[tex]s = \frac{l}{\sqrt{2mE}}[/tex], for impact parameters "s" and angular momentum "l"
[tex]\sigma (\Theta) = \frac{s}{sin \Theta} \vert \frac{ds}{d \Theta} \vert[/tex], differential cross section
[tex]\sigma_{T} = \int \sigma(\Omega)d\Omega = 2 \pi \int \sigma (\Theta) sin \Theta d\Theta[/tex], total scattering cross section
Attempt at Solution
Presumable, I need to find an equation between the impact parameter s and the scattering angle. From there I can answer both questions.
Perhaps if I found the equation of an orbit with eccentricity, and then substituted the angular momentum expression above in, I could arrive at such an expression. (This is what the author of our text did for the Coulomb potential.)
As far as I can see, the potential for a hard sphere is
[tex]V(r) = \left\{ \begin{array}{rcl} \infty & \mbox{for} & |r|<R \\ 0 & \mbox{for} & |r|>R \end{array}\right[/tex]
But I don't see how I can derive an orbit equation, as this isn't a potential that allows for orbits!
I think I need some expression relating the above potential V with angular momentum l, so that I can substitute in the expression for s, and work from there.
Any thoughts?
draw a circle at the origin (the hard sphere) and use geometry to relate the scattering parameter to the outgoing angle. sorry, it's hard to describe the proceedure w/out pictures and I don't have time to draw and upload one. But this is a pretty standard problem and is treated in a lot of texts. I think Griffiths reviews the classical calculation of hard sphere cross-section in his QM text.
malawi_glenn said:
Here you can find all you need to calculate scattering problems;)
http://farside.ph.utexas.edu/teaching/qm/lectures/node66.html
The key-sections are "The Born approximation" and "Partial wave expansion"
The Born approximation doesn't work for a *hard* sphere.
Also, I wasn't sure whether the OP wanted the classical or the QM calcuation, but it sounded to me like he is interested in classical... in which case the partial wave expansion is also a red herring.
No it does not work in hard spheres, I should have said that Born Appro is in general where one starts with QM scattering. Then one introdues partial waves etc..
Ok well I have no idea if he wanted to do that in Classical mechanics
Thanks for the link. That's a very helpful set of webpages, although I'm really just interested in the classical regime.
Yep - on the train today I think I sketched out a rough solution. I just needed to back away from the terse way scattering was covered in my text, and think about it more basically. I'll post some of my solution if there's time later. Thanks.
it's good to hear you made some progress. cheers.
