What is the force constant of the spring in a collision between two blocks?
The discussion revolves around a physics problem involving a collision between two blocks and the calculation of the force constant of a spring. The scenario includes two blocks of equal mass, where one is in motion and the other is at rest, leading to a spring compression during the collision.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss energy conservation principles and the relationship between kinetic and potential energy during the collision. There are inquiries about the methods used to arrive at specific values and the need for clarity on the variables involved.
There is ongoing dialogue about the correct application of formulas and the interpretation of variables. Some participants express uncertainty about their calculations and seek clarification on the concepts involved, while others provide guidance on the equations that should be used.
Participants mention difficulties in rearranging equations and understanding specific terms, such as the common velocity at maximum compression. There is a sense of frustration regarding the learning process and the need for further assistance to grasp the underlying concepts.
PhysicsOPhun
Hi, I Need to know exactly how to solve this...I just can't take it anymore. The only reason I'm so into it now is because I don't get it. I promised my girlfriend I would help her and now she's annoyed because I get more into it than she does. But anyway, someone..PLEASE tell me what has to be done here. I'm sure its something simple but I have no more brain power to even remotely try.
Two blocks, each with a mass 0.40 kg, can slide without friction on a horizontal surface. Initially, block 1 is in motion with a speed v = 1.2 m/s; block 2 is at rest. When block 1 collides with block 2, a spring bumper on block 1 is compressed. Maximum compression of the spring occurs when the two blocks move with the same speed, v/2 = 0.60 m/s.
If the maximum compression of the spring is 1.9 cm, what is its force constant?
I came up with 111N/m but only because I followed a patern, didn't feel like I knew what I was doing...is that right? 111?
Well, how did you get that answer; helping you will be easier if we know your way of solving and possible errors in it.
It would have been better if you had posted your work.
Need some water ??
anyways, its Energy conservation.
[tex]\frac{mv^2_1}{2}=2 \frac{mv^2_{common}}{2}+\frac{Kx^2}{2}[/tex]
K is force constant, x is compression.
I set the change of potential energy equal to the change in kinetic energy. Then I took final velocity .6m/s and subtracted initial velocity 1.2m/s and set the product of that to equal force constant times the amount the spring collapsed. Having all those values, I calculated for "k".
I'm sorry, but I didn't get you properly. Can you post your work here.
{mv^2_{common} - Would this be the value 2/v = .60m/s ? and in terms of mass, do I just double the mass of each box?
Oh, and Sourbah...putting up my work would not help, it's most definatley wrong. I just basically guessed...not much learning there.
Use the equation which google spider putted up in post #3, I'm not sure you are using the same equation. If you still don't get, just post again with your difficulty
I have trouble rearranging the variables to solve for the one I need. Also, I don't understand what mv^2common is...
What will this equation look like with my numbers plugged in. I want to work at backwards, understand it conceptually...
[tex]\frac{mv^2_{common}}{2}[/tex] is the mass of each body (common in this case) multiplied by the velocity (common at the instant of maximum compression); its the KE at the time of maximum compression.
Just write up the values of those variables in the equation which you know, we'll see what remains and how can it be calculated (You may feel irritated with my replies but remember, once I tell you the solution, the fun will be over)
I'm not irritated, I've already gone through that stage...I'm just in my "got to have the answer" so I can figure out what had to be done to get it. I don't know what the velocity was at the moment of maximum compression. I don't know how to calculate to get those values.
I have:
(.4kg)(1.2m/s)^2 / 2 = 2(.8kg)(1.2) /2 + K(.019m)/ 2
How does that look to you?
thank you tiny tim...i remember. Really, if there's something that's troubling me...it's very hard for me to get out of the cycle, like my brain shuts down. If I had the answer, and the other values which I don't know...i could work backwards and make perfect sense of it all...
I have:
Dude, that should look like this :
(.4kg)(1.2m/s)^2 / 2 = 2(.4kg)(0.6)^2 /2 + K(.019m)^2 / 2
Thanks to everyone who offered their help today... I've spent a week reading a physics book and have been very into it. I'm just doing it for myself so that I could help my friends and family with it if need be. It's a lot harder than I expected but hopefully with some help myself I'll be able to get on top of it soon.
