Calculating Work and Kinetic Energy in a Vertical Helicopter Lift
The discussion revolves around calculating the work done by a helicopter lifting an astronaut vertically with a constant upward acceleration. The problem involves concepts from mechanics, specifically work and kinetic energy, as well as forces acting on the astronaut during the lift.
  • The original poster attempts to calculate work using different formulas but expresses uncertainty about their results. Some participants suggest finding the force required to lift the astronaut and using it to calculate work. There are questions about the correct expression for force and its components.
Participants are exploring various interpretations of the problem, with some providing guidance on how to approach the calculations. There is acknowledgment of the need to consider both the force exerted by the helicopter and the gravitational force acting on the astronaut.
There is a mention of the astronaut's mass and the vertical distance involved, as well as the upward acceleration, but no explicit consensus on the correct method or final calculations has been reached.
shenwei1988
A helicopter is used to lift a 72.7 kg astronaut 16.9 m vertically out of the ocean by means of a cable. The astronaut rises with constant upward acceleration of magnitude 7.23 m/s2 until she reaches the helicopter.
a) How much work is done by the helicopter on the astronaut?
W=1/2MV^2=FS
first try: V^2=2as W=mas=8882.9949J wrong
second try: F=mg W=mgh=12052.8603J wrong
someone help me please, thank you so much!
First find the force required to lift the person. Then use work is force times displacement to find the work.
is the force mg ?
Use Newton's Second Law.
F = m*a
Force of helicopter - mass of astronaut * g = mass of astro * 7.23
Therefore the Force the helicopter must exert is 7.23 m + mg
Work = Force x Distance, so its just (7.23 m + mg) (16.9) Joules. Good luck!
yeah, i forgot to add the force of helicopter. thank you man!
  • · Replies 58 ·
  • · Replies 56 ·
