Solve Work Homework: -2.0cm & 4.69cm (Springs & Force 89N)
  • Thread starter Thread starter A_lilah
    Springs Work
The discussion focuses on solving a physics homework problem involving a spring-block system where a force of 89 N is applied to hold a block stationary at x = -2.0 cm. The spring constant (k) is calculated as -4450 N/m, and the work done on the system is 4 J. The final position of the block is determined to be 4.69 cm, with the need to identify the smaller position value. The analysis confirms that the positive work done results in an increase in potential energy, while the spring constant remains positive.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with work-energy principles in physics
  • Ability to manipulate algebraic equations for solving quadratic forms
  • Knowledge of potential energy in spring systems
  • Learn about the implications of negative spring constants in physics
  • Study the relationship between work done and potential energy in spring systems
  • Explore advanced applications of Hooke's Law in real-world scenarios
  • Investigate methods for solving quadratic equations in physics problems
Students studying physics, particularly those focusing on mechanics and energy systems, as well as educators looking for examples of spring dynamics and work-energy principles.
A_lilah
In the figure below, we must apply a force of magnitude 89 N to hold the block stationary at x = -2.0 cm. From that position we then slowly move the block so that our force does +4.0 J of work on the spring-block system; the block is then again stationary. What is the block's position (x)? (There are two answers.)
---cm (smaller value)
---cm (larger value)
W = .5 * [-k(xfinal^2) + k(xinitial^2)]
k = spring constant = force / distance stretched (or compressed)
1. Find the spring constant:
K = 89N / -.02m = -4450 N/m
2. Plug values in
W = 4 J = .5 * -4450N.m * [ -xf^2 - xi^2]
The initial distance from 0 was -.02m so I plugged that in for the initial distance and solved for the final distance, which = .0469 m = 4.69cm.
This was the right answer, but I'm not sure in which direction it was (although it was the larger value) and or how to find the smaller one. Would I add the initial distance instead of subtract it?
[tex]x_{i}[/tex] = 0.02 m
F = 89 N
W = 4 J
[tex]\vec{F_{spring}}[/tex] = -kx
The positive work done on the system means that energy from compressing the block into the spring more was converted into the potential (spring) energy, and the potential energy increased. There is negative work done on the block, so [tex]\Delta[/tex]KE is negative.
+[tex]\Delta[/tex]PE = 4 J = -[tex]\Delta[/tex]KE = -[tex]\int[/tex][tex]\vec{F}[/tex] [tex]\bullet[/tex] d[tex]\vec{r}[/tex] = -[tex]\int[/tex][tex]\vec{F_{spring}}[/tex] [tex]\bullet[/tex] d[tex]\vec{r}[/tex] = -[tex]\int^{x_{f}}_{x_{i}}[/tex](-kx)dx = k[tex]\int^{x_{f}}_{x_{i}}xdx[/tex] = (1/2)k([tex]x_{f}^{2}[/tex] - [tex]x_{f}^{2}[/tex]).
So +[tex]\Delta[/tex]PE = 4 J = (1/2)k([tex]x_{f}^{2}[/tex] - [tex]x_{i}^{2}[/tex]).
To solve for k, we know that at a displacement of [tex]x_{i}[/tex] = 0.02 m, the block is at static equilibrium, and net force is zero. So,
F + [tex]F_{spring}[/tex] = 0
F + (-kx) = 0
k = F/[tex]x_{i}[/tex].
4 = (1/2)k([tex]x_{f}^{2}[/tex] - [tex]x_{i}^{2}[/tex])
[tex]x_{f}^{2}[/tex] = 4/(1/2)k + [tex]x_{f}^{2}[/tex]
[tex]x_{f}[/tex] = [tex]\pm[/tex][tex]\sqrt{8/k + x_{f}^{2}[/tex] = [tex]\pm[/tex]0.046880196 m
I think the negative number reflects that if the compressing force is released, the spring will push the block past [tex]x_{i}[/tex] toward zero so the displacement is in the other direction, but I'm not sure. The spring constant k is never negative. Feel free to correct any mistakes I've made.
  • · Replies 58 ·
  • · Replies 17 ·
