Velocity & Distance of Long Jumper on the Moon
  • Thread starter Thread starter aLiase
    Moon Velocity
The discussion revolves around a physics problem involving a long jumper's performance, specifically analyzing the jumper's initial velocity, jump distance on the Moon, and time spent off the lunar surface. The subject area includes kinematics and gravitational effects on different celestial bodies.
  • Mixed
  • Participants explore the initial velocity components of the jumper, questioning the assumption that the vertical initial velocity is zero. There is discussion about the calculations for time to maximum height and the determination of angles based on horizontal and vertical velocities.
The conversation is ongoing, with some participants providing feedback on the calculations and assumptions made by the original poster. There are multiple interpretations of the jumper's motion, particularly regarding the initial vertical velocity and the effects of gravity on the Moon.
Participants note discrepancies in the equations used and the assumptions about the jumper's trajectory, particularly in relation to the different gravitational forces on Earth and the Moon. There is a focus on ensuring the correct application of kinematic equations.
aLiase
Long jumper jumps 8.12 m, reaching a height of 0.84 m half way through his jump. What was his velocity as he left the ground? Also, how far would he be able to jump on the moon (g = 1.63 m/s^2) and how much time would be spend off the lunar surface.
d = v1 + at^2 / 2
v = d/t
Ok, so I got the answer for the first part, but I just need a recheck from someone, The initial velocity as the jumper left the ground is 10 m/s in the horizontal direction and 0 in the vertical direction? The reason that I'm not sure of this answer is because when I find the angle (22 degrees) the answer becomes 9.27 m/s.
Now the second part is what I'm having problems in because the only variables known are the following:
Horizontal Direction:
V1 = 10 m/s
a = 0 m/s^2
Vertical Direction:
V1 = 0 m/s
a = 1.63 m/s^2
I also got the time from the first part which would be 0.82 seconds, but since the gravity/acceleration is different from Earth shouldn't it take longer for the jumper to go from one point to another?
You're missing a t in your equation for d
So he...jumps in a straight line, skidding along the ground? I believe they call that running(harhar *crickets chirp*)The angle for that would be 0, so I'm not sure how you found 22 degrees from that, unless you did two different approaches, in which case your answers contradict
And then for some reason on the moon you switched it and he jumps straight up. Although I think that's a typo, it's still the same issue with the other case
Ok, this is how I did it step by step.
First I found the time it toke from the ground to the maximum height using:
Vertical direction:
d = v1 + a(t)^2 / 2
0.82 = 0 + 9.81(t)^2 / 2
0.82 / 4.905 = t^2
t = 0.41
t(total) = 0.82
Then I multiply that by 2 to get the time it takes for him to jump from one point to the other.
Now I get the initial velocity since I have time I do:
Horizontal direction:
v = d / t
v = 8.12 / 0.82
v = 10 m/s
Then I used the equation v(f)^2 = v(i)^2 + 2ad to find the final velocity in the vertical direction:
v(f)^2 = 0 + 2(9.81)(0.84)
v(f) = sqrt(2(9.81)(0.84))
v(f) = 4 m/s
Then I used Tan(theta) = vertical / horizontal:
theta = tan^-1 (4 / 10/)
theta = 22 degrees
And that how I got the 22 degrees
Why are you assuming the initial velocity in the y direction is 0? He would never leave the ground
The reason you get an answer that kind of makes sense is because you forgot to include the negative when dealing with his vertical acceleration from gravity, so you're saying he starts with no initial vertical velocity, yet has a final vertical velocity of 4 m/s
So he falls up?
  • · Replies 30 ·
