Geometric algebra cross product
The discussion focuses on the algebraic manipulation of the cross product in geometric algebra, specifically in the context of rotating frames. The key equations presented involve the derivative of a vector fsubk with respect to time, expressed as d/dt (fsubk) = omega X fsubk, where omega is the angular velocity. The manipulation shows that omega X fsubk can be represented as both the dot product of (-I omega) and fsubk, and the dot product of fsubk and (I omega), utilizing the properties of the pseudoscalar I. The conversation emphasizes understanding these algebraic steps and their implications in geometric algebra. Overall, the thread seeks clarification on these concepts within the framework of geometric algebra for physicists.
krcmd1
Homework Statement [/b]
my text (Geometric Algebra for Physicists, by Doran and Lasenby), p. 69, deals with rotating frame {fsubk} (I assume in 3D)
d/dt (fsubk) = omega X fsubk omega being angular velocity
then
omega X fsubk = (-I omega) dot fsubk = fsubk dot (I omega), where I is pseudoscalar and (I omega) is I think the geometric product of I and omega.
I don't understand these algebraic steps. Can someone explain?
I did follow earlier explanations of why with vectors a,b that a X b = -I(a wedge b)
If I have posted this to the wrong forum, would the moderators kindly forward it to a more appropriate one?
Thank you all very much!
Ken Cohen
Homework Equations d/dt (fsubk) = omega X fsubk omega being angular velocityomega X fsubk = (-I omega) dot fsubk = fsubk dot (I omega), where I is pseudoscalar and (I omega) is I think the geometric product of I and omega.The Attempt at a Solution The first equation is just the derivative of the vector fsubk with respect to time. The second equation is saying that the vector omega X fsubk is equal to the dot product of (-I omega) and fsubk and also equal to the dot product of fsubk and (I omega). This is just the result of a few algebraic manipulations, using the fact that for any vectors a and b, a X b = -I(a wedge b) and a dot b = I(a dot b).
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
