Max height expressed with v, theta, and g
The discussion revolves around determining the maximum height of a projectile using conservation of energy principles, specifically expressing it in terms of initial velocity (v), launch angle (theta), and gravitational acceleration (g).
  • Participants explore the relationship between kinetic and potential energy, attempting to derive the maximum height formula. Questions arise regarding the correct placement of trigonometric functions and the consideration of vertical velocity.
Some participants have provided guidance on refining the approach, suggesting that focusing on vertical velocity may clarify the derivation. There is an acknowledgment of mistakes in the initial attempts, but no consensus has been reached on a final expression.
Participants are working under the constraints of expressing the height in terms of specific variables and are questioning the assumptions made regarding the components of velocity in the energy equation.
uber_dzl
[SOLVED] max height expressed with v, theta, and g
what is the max height of a projectile with velocity v at an angle theta using the conservation of energy? express in terms of v, theta, and g
1/2*m*v^2=mgh
i tried and got (v^2*sin(theta))/2g (wrong)
You've got the right idea. In fact I think you're close. Actually type out your work and show us, see if you spot the mistake
((1/2)m(v^2)*sin(theta))=mgh...then ((1/2)m(v^2)*sin(theta))/mg=mgh/mg...then the m cancels leaving me with (v^2*sin(theta))/2g=h
is my issue the placement of sin(theta) in the equation before i solve for h?
wow! what a tedious mistake...it was the placement of the exponent and parenthesis that was wrong...
thanx
Well my issue was you start here
1/2*m*v^2=mgh
It's the VERTICAL velocity you care about, it's 1/2*m*Vy^2=mgh
Vy=Vsin(theta) so you get 1/2*m*V^2sin^2(theta)
