How Is the Spring Constant Calculated from Block Compression and Friction?
The discussion focuses on calculating the spring constant (k) for a block compressing a spring after sliding on a rough surface. Given a 1.8 kg block with an initial speed of 2.0 m/s, it compresses the spring by 0.11 m before stopping. The coefficient of friction is 0.560. The kinetic energy (Ek) of the block is calculated as 3.6 J using the equation Ek = 1/2 mv², and the frictional force is determined using Ff = μFn, where Fn equals the gravitational force acting on the block.
  • Understanding of kinetic energy (Ek = 1/2 mv²)
  • Knowledge of potential energy in springs (Ep = 1/2 kx²)
  • Friction calculations using Ff = μFn
  • Basic principles of Newton's laws of motion
  • Calculate the spring constant (k) using the relationship between kinetic energy and potential energy.
  • Explore the effects of varying the coefficient of friction on the spring constant calculation.
  • Investigate the impact of different block masses on the spring compression and energy transfer.
  • Learn about energy conservation principles in mechanical systems.
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to explain the relationship between kinetic energy, friction, and spring constants.
soul5
A 1.8kg block slides on a rough, horizontal surface. The block hits a spring with a speed of 2.0m/s and compresses it a distance of 0.11m before coming to rest. The coefficient of friction between the block and the surface is 0.560. What is the force constant of the spring?
Ep=1/2kx^2
Ek=1/2mv^2
I used Ek=1/2mv^2 to find Ek and I got 3.6J. I can use Ff=uFn to find force friction, but I don't know what to do? help.
Since you know the mass of the object you would also know the Force of Gravity. Since force of gravity = Normal Force whenever its perfectly horizontal, then you could use that number you got times mew to get your frictional force
  • · Replies 37 ·
  • · Replies 16 ·
