Simple problem 3x = 1 (mod 16), find all possible values of x mod 16
  • Context: High School
  • Thread starter Thread starter bobthebanana
The discussion revolves around solving the congruence equation 3x = 1 (mod 16) and finding all possible values of x modulo 16. Participants explore various methods and approaches to tackle the problem, including systematic techniques and trial and error.
  • One participant expresses difficulty in solving the equation and seeks assistance, stating 3x = 1 + 16k, where k is any integer.
  • Another participant suggests that there are only 16 possible values for x and questions which ones satisfy the equation.
  • A participant proposes a systematic approach to solving similar problems, mentioning the Chinese Remainder Theorem in the context of a different modulus (2008).
  • One contributor provides a specific solution, stating that x = -5 and k = -1, and describes a general form for the solution as x = -5 + 16t.
  • Another participant notes that since 3 is relatively prime to 16, the solutions form a permutation of the multiplicative group, implying a unique solution exists.
  • Discussion also includes a consideration of the problem under a different modulus (2008), with suggestions for using systematic ideas and inspection to find solutions.
  • A later reply reiterates the initial equation and derives that the smallest positive value of x is 11, confirming it through modular arithmetic.
Participants express differing views on the methods to solve the problem and the nature of the solutions. While some suggest a unique solution exists, others explore the possibility of multiple values and different approaches, indicating that the discussion remains unresolved.
Some participants reference the need for specific conditions, such as the relationship between k and moduli, and the implications of the greatest common divisor in their reasoning, which may not be fully explored in the discussion.
bobthebanana
simple problem... 3x = 1 (mod 16), find all possible values of x mod 16
so this is what I've come to:
i'm stuck though, any help?
thanks
Well, there are only 16 possible values for x; which ones work?
Well is there a systematic way to solve a problem like this?
what if it were mod 2008
The systematic way is to use http://www.cut-the-knot.org/blue/chinese.shtml"
well, you put 3x-16k=1
by simple inspection i get the solution x=-5 and k=-1 , since the congruence is purely linear the solution can be written as
x= -5+16t and k= -1+3t where 't' is just any integer
the smallest positive solution is x=11 and k=2
To solve the general congruence ax+by=c
a) using trial and error find a paritcular solution , let's say x=m and y=n
b) we are supposing that gcd (a,b)=1 , the solution then may be written as
x= m+bt y=n-at for any integer 't'
This problem has showed up by the same author in General Math, under "Simple Problem 3X==1 (16)
I answered it there: 3 is relatively prime to 16, thus the elements 3x1, 3x2, 3x3...3x15 are all distinct, and simply form a permutation of the original multiplicative group. That is to say...there is only a single answer to your problem.
You can see that also by:
Then all you have to do is find that one number. Hint(1): It can't be a multiple of 2. Hint(2): Look for a solution of and then subtract that number from 16.
bobthebanana: what if it were mod 2008? (3x==1 Mod 2008)
They are certain more or less systematic ideas. 2008 =8x251, so you could try working out solutions for 251 and for 8 and use the Chinese Remainder Theorem.
However with a simple modulus like 3, we can use inspection.
We have the equation 2008K +1 = 3j. It happens to be that 2007 is divisible by 3, in fact, by 9. Thus 2008 is one more than a multiple of 3, and so is 1. Thus we need k=2. This gives us:
[tex]\frac{2x2008+1}{3} = 1339[/tex] So X=1339 is the answer.
thanks
As Robert pointed out with respect to 2008, 16 = 1 mod 3 so k must equal 2 mod 3 since
1 + 16k = 3x
1 + k = 3 mod 3
k = 2 mod 3
so the smallest positive value of x is (2*16 + 1)/3 or 11.
3*16/3 = 16 so x = 11 +16t
10K
  • · Replies 25 ·
  • · Replies 17 ·
