Locating Object & Image with a Converging Lens
A converging lens with a focal length of 7 cm produces an erect image measuring 1.10 cm tall from a real object that is positioned to the left of the lens. The object distance can be calculated using the lens equation 1/f = 1/o + 1/i. Additionally, a second converging lens with a focal length of 12 cm creates a virtual image 5 mm tall, located 19 cm to the right of the lens, requiring the object distance to be determined with the correct sign using the same lens equation and the magnification formula m = -i/o.
  • Understanding of lens equations, specifically 1/f = 1/o + 1/i
  • Knowledge of linear magnification, defined as m = -i/o
  • Familiarity with the concepts of real and virtual images
  • Basic skills in solving algebraic equations
  • Explore the application of the lens equation in various optical systems
  • Learn about the characteristics of real versus virtual images in optics
  • Investigate simulation tools for visualizing lens behavior, such as ray tracing software
  • Study the effects of different focal lengths on image formation
Students studying optics, physics educators, and anyone interested in understanding the principles of lens behavior and image formation.
eku_girl83
1) Aconverging lens with a focal length of 7 cm forms an image of a 4 mm tall real object that is to the left of the lens. The image 1.10 cm tall and erect.
Where is the object located?
Where is the image located?
2) A converging lens with a focal length of 12 cm forms a virtual image 5 mm tall, 19 cm to the right of the lens.
Determine the position of the object. (Give the object distance with the correct sign).
Determine the size of the object.
You'll need the lens equation: 1/f = 1/o + 1/i, and the definition of linear magnification: m = -i/o.
Look up how these equations are used and give the problems a try.
There is a good simulation program picture what about it
http://www.geocities.com/mrfarag
