Replacing vs. Cleaning HEPA Filters: What's the Best Choice?
  • Thread starter Thread starter Ulysees
    Filter
The discussion revolves around the effectiveness and implications of cleaning versus replacing HEPA filters. Participants explore various methods of cleaning, such as using compressed air or detergents, and the potential consequences of these methods on filter performance and safety. The conversation touches on both theoretical and practical aspects of filter maintenance.
  • Some participants question whether blowing a HEPA filter with compressed air is sufficient for cleaning, suggesting it might just release trapped particles back into the air.
  • There is concern that cleaning methods could compromise the filter's structure and effectiveness, particularly if strong detergents are used.
  • One participant notes that true HEPA filters, such as bag filters, are not designed to be cleaned with compressed air, implying that many residential filters may not meet HEPA standards.
  • Another participant expresses a preference for replacing filters rather than risking the integrity of the filter through cleaning attempts.
  • Some participants highlight that a used filter might perform better due to the accumulation of dirt, which could enhance its filtering capability.
Participants generally disagree on the best approach to maintaining HEPA filters, with some advocating for replacement and others exploring cleaning methods. There is no consensus on whether cleaning is effective or safe.
Participants express uncertainty about the specific types of HEPA filters being discussed, which may affect the validity of cleaning methods proposed. The discussion also reflects a lack of clarity on the definitions and standards of HEPA filters.
Ulysees
Is it enough to just blow a HEPA filter with high-pressure compressed air, instead of replacing it?
In other words, do microbes get blown away?
That would defeat the entire purpose of having used a HEPA filter if you just blew everything back into the air, wouldn't it?
I'm not sure how HEPA filters actually work, though, so can't tell you if there's a way to clean them and reuse them, or if they must be disposed of every time they get dirty. The engineers might know more about this in their applications, so I'm going to move this thread over to engineering and see if you get a better answer there.
Alright.
Btw, the idea is to blow the filter outside.
Which I've already done.
I don't think you will get much cleaning efficiency by trying to blow the captured particles and microbes back out. Part of how the HEPA filter works is that it traps and embeds the particles -- they don't just get lightly stuck on the outer surface of the outermost fibers:
http://en.wikipedia.org/wiki/HEPA_filter
I know I sure wouldn't want to use a HEPA mask that somebody had used before, and tried to clean with compressed air. They're disposable for a reason.
Thank you berkeman.
What if you wash the filter, with a strong detergent or whatever?
My guess is that if you try to clean these disposable HEPA masks with something strong enough to get rid of the particles and microbes, that you will also compromise the tiny fibre structures that do the filtering.
Also, what kind of hepa filter are we talking about here? Oftentimes, residential grade filters may say they are hepa, but they really aren't. Ie, a real hepa filter (such as a bag filter) wouldn't be cleanable with compressed air. What I'm guessing you are dealing with is just a very good regular pleated media filter.
This is probably the most important reason not to mess with the HEPA filter. I think you need to know a lot more about the HEPA system before you try to use detergents on it as well. They are kind of expensive, so i see your reasoning to clean them. but as efficient as they are, i would personally just buy another one than chance it. Also keep in mind that a slightly used filter sometimes works better, some trapt dirt pieces will actually trap other dirt pieces.
11K
  • · Replies 22 ·
