Solving Static Friction: 3 kg Block & 99 N/m Spring
  • Thread starter Thread starter glasshut137
    Friction Springs
The discussion centers on a physics problem involving a 3 kg block colliding with a massless spring with a spring constant of 99 N/m. The block, moving at 1.5 m/s, compresses the spring by 26.11 cm. Given a coefficient of static friction of 0.703416, participants analyze whether the block remains at rest or bounces back after full compression. The consensus indicates that the static friction force is greater than the spring force, confirming that the block will remain at rest.
  • Understanding of Newton's laws of motion
  • Knowledge of spring mechanics, specifically Hooke's Law
  • Familiarity with static and kinetic friction coefficients
  • Basic algebra for calculating forces and distances
  • Study Hooke's Law and its applications in spring mechanics
  • Explore the calculations of static and kinetic friction forces
  • Learn about energy conservation in spring-block systems
  • Investigate real-world applications of static friction in engineering
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for examples of spring dynamics and friction analysis.
glasshut137
A 3 kg block collides with a massless spring of spring constant 99 N/m attached to a wall. The speed of the block was observed to be 1.5 m/s at the moment of collision.
(3 of 3) Given: the coefficient of static friction between the floor and the block is .703416. Does the block remain at rest or does it bounce back off of the spring once the spring is fully compressed?
I already solved the first 2 parts of the question, i found that the spring will compress 26.11 cm. Also, I found that the coefficient of kinetic friction is .467 if the maximum distance to which the spring is compressed is 15.667 cm.
My guess is that the block would remain at rest because it would would a larger force to break through the force of static friction. Can someone tell me if I'm right or wrong and can please explain? thanks so much.
Well you can computer the force of the spring and the static friction and check if the force that the spring exerts is indeed too small.
This shouldn't be hard since you correctly answered 1&2 and computed the compression of the spring
  • · Replies 27 ·
11K
  • · Replies 16 ·
