Weight in Terms of Distance From Earth
The discussion revolves around determining the height above the Earth's surface at which an astronaut's weight is half of their weight on Earth. The subject area includes gravitational forces and the mathematical relationships governing them.
  • Participants explore the gravitational force equation and its implications for weight at different distances from the Earth. There is a suggestion to clarify variable definitions to avoid confusion in calculations.
Some participants have provided insights into the relationships between gravitational force and distance, while others have noted the importance of using distinct variables for clarity. The discussion is ongoing, with various interpretations and approaches being explored.
There is a mention of the Earth's radius and the need to differentiate between the radius of the Earth and the radius at which the astronaut's weight is being calculated. The original poster's teacher provided a specific value related to the radius of the Earth, which is also under consideration.
bfr
[SOLVED] Weight in Terms of Distance From Earth
At what height above the Earth's surface will an astronaut have a true weight that is one half his weight on earth?
F=G(m1*m2)/r^2
(GM)/(4*pi^2)=(R^3)/t^2
I did:
F/2=(G*m1*m2)/r^2
r=sqrt((2*G*m1*m2)/F)
My teacher got sqrt(2) times the radius of the earth. Where do I go from there?
bfr said:
F=G(m1*m2)/r^2
I did:
F/2=(G*m1*m2)/r^2
Hi bfr!
You're confusing yourself by using the letter r for two different distances.
Hint: call the Earth's radius r, and call the radius you're looking for s.
Then write two equations, one with r and one with s.
Then … does that help? :smile:
g=GM/R^2
so g is directly proportional to 1/R^2
g'/g = R^2/R'^2
1/2=R^2/R'^2
let R = 6400*1000 m
R'^2 = 2R^2
R' = sqrt2 R = 9050km
atitude = 9050-6400 =2651km above the Earth's surface
of coz , u may realize that
GM =gRe^2 , where Re is the radius of the Earth
then
g'= gRe^2/R'^2
which is the same.
Yes! :smile: But a bit long-winded.
You could just say:
F =G.m1.m2/r^2
F´ =G.m1.m2/r´^2
so F/F´= r´^2/r^2 = (r´/r)^2.
Do you see the advantage now of being careful to use different letters?! :smile:
[size=-2](if you're happy, don't forget to mark thread "solved"!)[/size]​
  • · Replies 22 ·
  • · Replies 39 ·
  • · Replies 63 ·
