Finding a Basis for the Kernel of a Differential Operator
  • Thread starter Thread starter simpledude
    Basis Kernel
The problem involves determining the kernel of a differential operator defined on the vector space of continuously differentiable functions. Specifically, the operator T maps a function u to the expression u''(x) + u'(x) - 2u(x), and the goal is to find the kernel of T and establish a basis for it.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definition of the kernel and explore the implications of the differential equation u''(x) + u'(x) = 2u(x). There are attempts to find solutions and establish linear independence among them. Questions arise about the nature of the solutions and the validity of using initial conditions.
The discussion includes various attempts to solve the differential equation and establish a basis for the kernel. Some participants suggest methods for proving linear independence, while others question the appropriateness of certain approaches. There is an ongoing exploration of the implications of the solutions found.
Participants note that initial conditions may not apply in this context, and there is a focus on the linearity of the operator T. The discussion also touches on the use of limits and the behavior of exponential functions as x approaches infinity.
simpledude
Let V = C(R,R) be the vector space of all functions f : R −> R that have continuous
derivatives of all orders. We consider the mapping T : V −> V defined for all u belonging to V , by T(u(x)) = u''(x) + u'(x) − 2u(x). (Where u' is first derivative, u'' second derivative)
Question: Determine Ker{T} and find a bsis of Ker{T}
2. The attempt at a solution
So as far as I understand the Ker{T} is the set of elements in T that maps into
the zero vector, i.e. Ker{T} is when T(u(x))=0 (is this correct?)
So T(u(x)) = 0 only when u''(x) + u'(x) = 2u(x). So would the Kernel of T be all functions
u belonging to V such that u''(x) + u'(x) = 2u(x)
But in this case how can I compute the basis?
Thank you very much.
Best Regards,
SimpleDude
solve for u and show the solutions are linearly independent
Ok, so u(x) = [u''(x) - u'(x)] / 2
But that's only one solution, how can I get anoter one from the same equation?
(because if I use the same equaton, they both will be linearly dependent).
Any help will be appreciated -- thanks!
Ok I understand, and as far as the initial conditions go, if T is a linear operator
is it ok to say that u(0)=0 and u'(0)=0 ?
Because in that case everythign is 0 (both constants are 0, hence u(x)=0 )
no you won't have initial conditions, so if you solved it(i'm assuming you did), you should get that u is of the form,
u(x) = ae^(x) + be^(-2x) for some a, b in R, in particular, this means that
u belongs to span({e^(x), e^(-2x)} = B(I just called it B for notation), so now you've shown
that kerT is contained in spanB, and the other inclusion is obvious(you should check it to be sure), so kerT = spanB
Now just show it's independent, this might be trickier for you, so i'll get you started. We'll just use the definition of linear independence.
So suppose ae^x + be^(-2x) = 0 for some scalars a, b, in R.
We need to show a = b = 0.
hint: this equation must hold for ALL values of x, so try some different values and try to force a = b = 0.
Ahhh :)
Can I create a matrix of coefficients of
u(x) and u'(x), namely:
u(x) = ae^-2x + be^x
u'(x) = -2ae^-2x + be^x
And solve AX=0 via gauss?
Doing so I get a matrix of the form
1 1
0 1
Hence the are linearly independent, furhermore (1,0) and (1,1) form a basis of Ker T.
The B I wrote above will be your basis, remember B is a subset of V which is a space of functions, (1, 0) and (1, 1) are elements of R^2, they certainly aren't functions!
I gave you a hint, it's a good one, try it!:)Edit: Another way is to compute the wronskian of e^(-2x) and e^x and notice it's nonzero, but imo it's better to do it the way I suggested. What I suggested is a good trick to keep around because it's useful in other places(like when working with dual spaces, etc).
Ok, that's not that hard.
Since: e^x != e^-2x for any values of x, except 0, and e^0 = 1.
The only way to satisfy the equation ae^x + be^x = 0
is if th coefficients a,b=0 i.e. a=b=0
Hence it is linearly independat and the basis of Ker T is indeed {e^-2x, e^x}
that's not enough, the way you wrote it isn't really correct, but the idea is correct!
We have ae^x + be^(-2x) = 0, we need to show a = b = 0. This equation holds for all values of x. So plug some values of x in.
Set x = 0. Then we get a + b = 0, so b = -a. Now go back to the original equation,
ae^x + be^(-2x) = ae^x - ae^(-2x) = a(e^x - e^(-2x)) = 0. Then a = 0, otherwise e^x - e^(-2x) = 0, that is e^x = e^(-2x) and this holds for all x in R, a contradiction(for example setting x = 1 shows it's clearly false).
Therefore b = -a = -0 = 0, so a = b = 0 and we have independence, and B is a basis as needed.EDIT: I edited my post to give you more since I noticed you were really close.
I hope this helps, it's a good trick to keep around.
Ok so more abstratly,
Let's take an arbitrarily large x, x --> infinity
The equation e^x will go to infinity
The equation e^-2x will go to zero.
So a(infinity) + b(0) = 0 is only satisfied if a=0
Now let's take x --> -(infinity)
Th equation e^x will go to zero.
The equation e^-2x will go to infinity.
So a(0) + b(infinitiy)=0 is only satisfied if b=0
Hence a=b=0
hehe thanks!
However, is my approach correct?
Can infinity be used?
Also Dan, if you don't mind me asking a more abstract question.
Let's say I wanted to show that T was a linear operator.
Can I independantly show each part of the operator? I mean can I show
u''(x) is linear, then u'(x) is linear, and -2u(x) is linear.
Then since they are all linear, a linear combination u''(x)+u'(x)-2u(x)
is also linear, hence T is a linear operator.
simpledude said:
hehe thanks!
Can infinity be used?Also Dan, if you don't mind me asking a more abstract question.
hmm no not really to the infinity thing, for practice you could show that {e^(bx), e^(cx)} is linearly independent if c != b. (using the same method I described)
As for showing T is linear, yes, exactly what you said! It's actually easier, from calculus you know that differentiation is a linear operator, ie, d/dx(u + v) = du/dx + dv/dx, d/dx(cu) = c*du/dx, and the same when you take the second derivative because the composition of linear operators is linear, so we had
T(u) = u'' + u' - 2u.
So from calculus, it's immediate that
T(u + v) = (u + v)'' + (u + v)' - 2(u + v)
= u'' + v'' + u' + v' -2u - 2v
= u'' + u' - 2u + v'' + v' - 2v
= T(u) + T(v)
and similarly T(cu) = cT(u)
where we used the fact that differentiation is a linear operator
Thank you sir!
