Titration of Buffers: NH2OH and HCl
  • Thread starter Thread starter Mitchtwitchita
    Buffers
The titration of 35.00 mL of 0.350 M NH2OH with 0.350 M HCl requires 35 mL of acid to reach the equivalence point. The initial pH of the NH2OH solution is calculated to be 9.68. After adding 10.00 mL of HCl, the pH drops to 6.220. At the equivalence point, the pH is determined to be 3.286, and after adding 40.00 mL of HCl, the pH further decreases to 1.645. These calculations utilize the Kb of NH2OH (6.6 x 10^-9) and the relationship between Ka and Kb for weak bases.
  • Understanding of weak base titration principles
  • Knowledge of pH calculations and logarithmic functions
  • Familiarity with the Henderson-Hasselbalch equation
  • Basic skills in stoichiometry and molarity calculations
  • Study the Henderson-Hasselbalch equation for buffer solutions
  • Learn about the relationship between Ka and Kb in acid-base chemistry
  • Explore advanced titration techniques and their applications
  • Investigate the significance of significant figures in chemical calculations
Chemistry students, educators, laboratory technicians, and anyone involved in acid-base titration experiments will benefit from this discussion.
Mitchtwitchita
You have 35.00 mL of a 0.350 M aqueous solution of the weak base NH2OH (Kb = 6.6 x 10^-9). This solution will be titrated with 0.350 M HCl.
(a)How many mL of acid must be added to reach the equivalence point?
(b)What is the pH of the solution before any acid is added?
(c)What is the pH of the solution after 10.00 mL of acid has been added?
(d)What is the pH of the solution at the equivalence point of the titration?
(e)What is the pH of the solution when 40.00 mL of acid has been added?
(a) Since the moles of acid and base are the same at the equivalence point, there will be 35 mL of HCl added.
(b)Kb = [NH3][OH-]/[NH2OH]
=6.6 x 10^-9 = x^2/.350
=4.8 x 10^-5
pOH = -log(4.8 x 10^-5)
=4.32
pH = 9.68
(c) moles NH2OH = 0.03500 L / 0.350 moles/L = 1.23 x 10^-2
moles HCl = 0.01000 L / 0.350 moles/L = 3.50 x 10^-3
NH2OH + HCl ---> NH3 + H20
Initial 1.23 x10^-2 3.50 x 10^-3 0
Change -3.50 x 10^-3 -3.50 x 10^-3 +3.50 x 10^-3
Equilibrium 8.80 x 10^-3 0 3.50 x 10^-3
NH2OH ---> NH3 + OH-
6.60 x 10^-9 = (3.50 x 10^-3)x/8.80 x 10^-3
[OH-] = 1.70 x 10^-8
pOH = -log[OH-]
=7.780
Therefore, pH = 6.220
(d) moles NH2OH = 1.23 x 10^-2
moles HCl = 1.23 x 10^-2
Initial 1.23 x 10^-2 1.23 x 10^-2 0
Change -1.23 x 10^-2 -1.23 x 10^-2 +1.23 x 10^-2
Equilibrium 0 0 1.23 x 10^-2
[NH2-] = 1.23 x 10^-2/0.0700 L = 0.176 M
NH3 + H2O ---> NH2- + H+
Initial 0.176 0 0
Change -x +x +x
Equilibrium 0.176 - x x x
Ka = Kw/Kb
=1.52 x 10^-6
Ka = [NH2-][H+]/[NH3]
1.52 x 10^-6 = x^2/0.176
[H+] = 5.17 x 10^-4
pH = -log[H+]
=3.286
(e)moles NH2OH = 1.23 x 10^-2
moles HCl = 0.04000 L / 0.350 moles/L = 1.40 x 10^-2
NH2OH + HCl ---> NH3 + H2O
Initial 1.23 x 10^-2 1.40 x 10^-2 0
Equilibrium 0 1.70 x 10^-3 1.23 x 10^-2
[H+] = 1.70 x 10^-3/0.07500 L = 2.27 x 10^-2 M
pH = -log[H+]
=1.645
Does this look right to anyone? If not could you please tell me where I'm going wrong? Also, do my significant digits look correct? I get confused on how they work with logs.
Lol...you go to Brock right?
  • · Replies 22 ·
